Question about Sharp Ref SJ-F75PS SL
Where can i buy parts online for that fridge? I need ASAP
I need the PC Board (SHARP SJ-F75PS-SL, SERIAL # R081100887)
Water under the veg. compartment in sharp SJ-T520R-SL refridgerater
Hi,at the back of the fridge there is useuly a drain hole if its blocked then instead of the water going out of the back of the fridge its staying in the fridge,if there is one just get a peice of wire and push down hole to remove any blockidge,also what can couse itis if your food in the fridge is tuching the back off the fridge wall then the water runs down the food inside the fridge instead off going down the drain hole.
hope this was some help,all the best.
Apr 18, 2015 | Sharp Refrigerators
My sharp SJ-F70PV-SL is not cooling properly
Switch off your ref for 8hrs till all Ice melt in freezer compartment. Switch on Ref and checked Air coming from Ref duct or not.
Apr 02, 2013 | Sharp Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
I am considering buying a sharp bottom freezer refrigerator (SJ-F78SP). I want to know if there is any problem with the cooling or the auto defrost system. I had a panasonic bottom freezer refrigerator...
I would not buy a Sharp refrigerator. They make decent TVs, but I would be cautious purchasing a fridge. But something american like GE or Whirlpool. It's just my suggestion.
Feb 23, 2011 | Viking DDBB363 Bottom Freezer Refrigerator
I need PC Board for the fridge
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 21, 2010 | Samsung RS2534 Side by Side Refrigerator
Sharp Ref SJ-F75PS SL Logo
22 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
