Question about Home
Tuaca neon light
Was wondering what the value of this light is. approx. has two small spots on the c and a where the yellow paint has come off.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 11 Answers
I would say $75 maybe at the most $85 the least i would say is about maybe $20
Posted on May 28, 2014
How do you do small body panel repairs on rust spots?
If it's just surface rust with no holes use a grinder and clean the spot to bare shiny metal. Use some spot putty and completely cover the metal. Then sand it down smooth and put some primer on it. When you sand it down pay close attention to your edges. Sand them into the paint so that you can't feel the difference between the patch and the old paint. After the primer dries use a spray can and paint the spot because primer will absorb water and you will have to do the repair again.
If the spots have small holes in them you should get a can of body fill called "Tiger Hair". It has fiberglass in the compound and will easily fix small holes. Use this before the spot putty and sand it smooth. Then cover that with a thin layer of spot putty to fill any imperfections, primer and paint.
If you have holes bigger than 1/2 inch then you should be able to get small wire mesh patchs at your local auto parts store. These will stick to the bare metal after grinding and you can put your tiger hair over that. This will be a bigger patch. It will need to be about 3 times bigger than the hole you are filling to be relatively unnoticable.
This won't give you a show car but it should keep inspectors off your back. Hope this helps.
Sep 02, 2010 | 2001 Ford Windstar
We don't like that the Lutron Diva dimmers only come with a "locator light" which means the dimmer is backlit when it is off. Can we just simply remove the small neon bulb in the dimmer? It seems like we...
The dimmer's performance would not be affected by removing the neon lamp. However, it will be important to snip the leads so they don't cause a short in the circuit board.
You could just use some high-temperature black paint and coat the neon lamp.
Jul 14, 2010 | Electrical Supplies
Something to make soft solder blend in more to gold color jewelry
Was looking for a patina - used in stained glass - this is what others suggest...
"I use gold leaf paint at my solder points in a stained glass piece to make it look like brass. Have repaired many pieces and used the gold leaf paint and works very well. I think the paint works better than the gold pen."
Gold'ish color at least - hope this helps... Dan
Dec 09, 2009 | Welding Tools
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
97 Dodge Neon removing headlight cover
There are a number of products that will help. They involve grit polishes and buffing pads. One made by Mother's works for me. Your local auto parts store can help you.
Oct 09, 2009 | 1997 Dodge Neon
A yellow light, to the left of the seatbelt light came on. I was wondering what this light is for since I don't have an owners manual
make sure your fluids are topped off it is a check engine light probally your computer when accesed will read a code from this light talk to a parts store the light will diagnose the problem
May 31, 2009 | 2004 Dodge Neon
Need to value a vintage snowboard
i have a black kemper rampage 150 with purple neon yellow neon and pink neon colours it is still in good conditions only 20.00 $
Jan 27, 2009 | Kemper Virtue Snowboard 152 cm WMS
Paint on stove top is coming off.
with smaller spots you can use appliance touch up paint and it should hold paint down and keep spots from getting bigger. Depending on how old the range is your landlord might be able to order a new top. I would voice my concern to the landlord and see what they might be willing to do to appease your concerns.
Jan 16, 2009 | Sears 61301 Gas Kitchen Range
Panasonic PT-61LCX65 61 -- Neon Yellow Lines
I called Panasonic and they are sending a repairman. My TV is 3 years old. They said they'd cover the repair as a one-time in-warranty even though it is out of warranty because they've been having problems with this model. Don't do like me and try to live with the problem.
Good luck to all that have this problem.
Sep 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Home Logo
64 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
