Where available mechanical fitter jobs - Computers & Internet
My house was built in 1993 and has a kozy wood burning fireplace. I want to remove it and install a regular gas insert. What does this entail to remove this one. Is there an easy solution?
leave the chimney as you need ventilation for the carbon monoxide that is produced by the burning gas
this is not a diy project so talk with a professional gas fitter to get advice on what is needed for the job
the conversion will be at a cost so you need good advice on the cheapest method available that can be done safely
Talk with many gas fitters for ideas
Sep 09, 2017 | Heating & Cooling
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
Why is propane gas range burners leaving soot on pans and now can smell gas.
soot is an indication that the air /gas ratio is too rich
it is adjustable but I strongly advise that a gas fitter do the job
you will need a gas fitter to stop the gas leak
Sep 25, 2015 | Kitchen Ranges
How do i replace the glass in my rear window of my 98 oldsmobile bravada?
this is a job requiring experience as if it is not done properly will leak
Take it to a windscreen fitter and they will have the jib done within the hour.. Some windscreen fitters will even come to your home to do the jib.
Jan 16, 2015 | Oldsmobile Cars & Trucks
My 2000 Acura TL 3.2 had no heat. It's flowing all cold air when i turned the temperature to 90 degree. Is it my thermosta had a problems? How to fix this?
Never seen one of these cars but if in doubt ask a local mechanic to have a look for you ,in the heater hose feed to the heater could be a electric solonoid type switch that opens the valve inside the water pipe housing that the solonoid sits on and it could somehting wrong here like either the solonoid isnt operating or no power being sent to it from the climatic control computer or the plunger inside the housing is stuck ,use a mechanic recomended by a friend or relative to check the type of system ,The parts are or can be expensive and i have removed the automatic valve and fitted a tap with a manual cable from a bicycle gear change before now but i cannot recommend this as although it works other people who answer questions on here are altogether happy with some of my cowboy jobs ,but i used to be a fleet fitter with lots of own company vehicles not a dealer fitter and the owner was a refugee from a concentration camp in poland and he didnt like spending money ,an under statement to say the least
Dec 01, 2011 | 2000 Acura TL
What is fitter?
it can mean a few things fitter could mean healthy (getting fitter)
or it could mean a persons job fitter who fits mechanical pieces together
hope this helps
Feb 19, 2011 | Computers & Internet
In the last week when trying to start my car.....it wont start. when turning the ignition key all l get is a 'click' l was advised by a friend to change the fuse which i did & for a couple of days all...
just put it into peugeot because in your job with the hours you cannot afford to play around,Doesnt your company have its own fitters ??? because fleet fitters are the best as they can repair anything ,so while your out driving your seddon atkinson or foden with the garner engine and 12 speed air operated gearbox they should be only to happy to fit a solonoid to the starter motor ,as this i think is failing with a high resistance in the coil causing the fuse to blow.,Now real fleet fitters should be able to strip and rewind the coil for you ,and if need be use the lathe and make a new part as well for you .Now as the so called service assistance mechanics like the AA/RAC well these are not real mechanics or the cream like fleet fitters but failed mechanics who become receptionists or so called breakdown call mechanics who do not like getting their hands dirty unlike the cream of all--- the fleet fitter ---who work away in all weather laying in a motorway service area in the snow changing a alternator on the side of the motorway or unfreezing frozen air pipes with a flaming rag tied to their favourite tyre lever or bringing you out a couple of gallons of old engine oil when you have blowen up the engine through not checking the oil level and fixing it so you dont get the sack .
Dec 09, 2010 | 2006 Peugeot 405
Clutch pedal noise Toyota avensis When i push the clutch is a litle blocking and nois
hi by the sounds of things this might be your thrust bearing in the clutch housing, or the presure plate springs have broken you will have to get them checked by a clutch fitter or mechanic, as this is a long and possibly expencive job...sorry its not much help
Feb 13, 2010 | 2005 Toyota Corolla
My 2001 Jetta TDI has 155k on it. The timing belt was replaced at 78k. What kind of service is required at this type of mileage? Ive had no problems and still get great mileage.
full service means different thing to different mechanics ,like to a fleet fitter it means a good strip and inspect ,to a dealer fitter it means a nice bonus job where the pen is mightier than the doing the actual work .
Nov 20, 2009 | 2001 Volkswagen Jetta TDI
Freestar temp gauge moves erratically and enigne not overheating.
try the dealers and get a dealer fitter on the job
Jul 09, 2009 | 2005 Ford Freestar
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
