Question about Denon Dra-700 Receiver Review, 3 Pgs, 1983, Full Test
Tuner on Denon Receiver not working
The tuner on this Denon Reciever is not working and is only producing static. I have opened the unit up and removed the tuner unit (MB014Ma1-DN). When I unscrewed the tuner unit and started the reciever again the tuner worked fine picking up stations (even without an antenae as I would expect). But as soon as I put the tuner unit back in place (as soon as it touches the back case of the receiver it only produces static again. Any ideas what could be the problem here?
SOURCE: my denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Posted on Jul 17, 2008
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
  • 5 Answers
SOURCE: Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Posted on Aug 29, 2008
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
  • 99 Answers
SOURCE: Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Posted on Jul 27, 2010
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Hey there,i have a avr3808, everything worked fine. Now i don't get any sound in tuner mode. tv,blu ray all work fine. I dont have sound in main zone, and no sound in any other zones in the house. Please...
Your tuner is need to resolder all components parts joints ,that is the symptom of loose connection or cold solder.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Denon AVR 3808Ci Receiver
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
No Picture on Mitsubishi v45605 rear projection tv
If it works the way you have it setup now, leave that way. Plug all your video sources to the denon if possible and leave it that way.
If the denon has the feature to change channels like a cable converter then you can use it or if you still have a VCR you can also use it as a tuner just to tune the cable channels and use the audio/video outputs from it to the TV or denon receiver.
The tuner might not even be available anymore and if it's, is expensive.
Good Luck.
May 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Dec 12, 2006 | Denon AVR-2802
Denon Dra-700 Receiver Review, 3 Pgs, 1983, Full Test Logo
110 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
