Question about Bose Lifestyle 20 System
Bose Lifestyle 20 very Dim display
Hi, I have a Lifestyle 20 with a very dim display, I have read where you can change a capacitor C19, but not sure if I have the same model? C19, 18, 17 and 16 are all very small surface mount devices, is this correct?
I don't seem to be able to find a 63V 100uF SMT in the same config?
Thanks for your help
  • 30 Answers
There are instructions available at www.AnyoneCanFixIt.com that has detailed pictures of this repair, step by step.
Posted on Aug 26, 2009
  • vcrsi Jan 28, 2011
    this is a place to share ideas, not to sell repair manuals.
    Problem Solver:
  • 7 Answers
There are five 100uf 50v through hole caps on the power supply pcb. You might as well replace ALL of the electrolytic caps on the board since Bose used cheap 85C caps instead of quality 105C ones. Install some Panasonic FC caps of the appropriate values from Digikey and your display should come back to life.
Posted on Mar 13, 2014
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
The digital readout on my bose lifestyle 25 system is so dim cannot see?????
Change all the capacitors on the power board and the display should light up again. Good luck
Feb 03, 2011 | Bose Lifestyle 25 System
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
No display lights on bose lifestyle 8 home theatre. System works though.
Displays die quite often on receivers just one of those things that happens.
Bose is pretty good about repair cost and timely in their turnaround. Here is a link to the support page
I would guess a replacement display would run about $150 installed plus you will have to ship your unit to them.
They like to do "flat rate" service plans which is one of those 50/50 deals most of the time you are better off just paying for the repair versus dealing with a service contract but you will have to find out whats available for your model.
Hope that helps
Feb 12, 2010 | Bose Lifestyle 8 series II System
I own a Bose Lifestyle 12 system and the display on the console has failed. All else works (ie: buttons and remote.) Is it possible to have it reasonably repaired, DIY or must I live with this as is? Thank...
Its working lifestyle 5, 8, 10, 12 receivers Its Easy fix you need open it up and on lover left corner on bottom first capacitor value 3.3uF needs to be replaced.I did all ready 3 units and its all work now
Oct 28, 2009 | Bose Lifestyle 12 System
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose LS5 display dead
I have a service manual with complete pcb layouts and circuit diagrams, including dis-assembly instructions, contact me in case someone is interested.
Jan 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5 ~ dead display fix
Hi the fix for a dead display is a faulty capacitor. Depending upon which board version you have, you need to replace the 33 uF / 63 volt capaitor. On some units this is C19 on the display board, on other units this capacitor is mounted on the main board and re-numbered, there is only one 33 uF on the unit so you should be able to find it.
Dave
Sep 21, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 20 System Logo
3,619 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
