Question about Microwave Ovens
Whirlpool VE 924 cooktop - Microwave Ovens
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
I have a whirlpool glass top stove and the cooktop light will not go off.
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Feb 19, 2011 | Whirlpool Microwave Ovens
The cooktop lamps on my Whirlpool MH6130XEQ-1 microwave do not work. Their receptacles receive 70 V AC, no matter whether and how many times the soft switch is pushed.
I just saw this inquiry today, and while you may have already dealt with this, here is my answer, in case it might help you or others:
We see and repair this on a regular basis with our $39.95 service. Details are here.
It's a problem caused when the cooktop lights fail or are removed or inserted with the power still on.
They short internally, and the resulting surge damages the control circuit board.
It can affect fan and oven light operation, keeping them from working or leaving them stuck on.
If you prefer to replace your control circuit board, you can order it (part number 8172054, formerly 4359661) for $168.39 plus
shipping from the Pros here.
moz-screenshot.pngmh6130xeq-1_panel_smaller.jpg?filename=mh6130xeq-1_panel_smaller.jpg&q=786obatqb1684s0931&o=4337&contentlength=75762&downloadid=ebf28cd0ae6c0b1566d991c489678ab1
Nov 14, 2010 | Whirlpool MH6141XK Microwave Oven
Whirlpool cooktop model # sc8900exb1 ---ignitor is activated with cooktop burners turned off
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 15, 2010 | Microwave Ovens
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool gold accuwave system above the range microwave
Small "d" indicates door. One or more of the door switches is not closing properly or have failed. Anything from a misaligned door to faulty components...Eric
Aug 07, 2009 | Whirlpool MH7140XF Microwave Oven
Cooktop bulb broke off inside receptical. Removed all, no work.
Try another bulb. Sometimes even new bulbs are defective.
Mar 20, 2009 | Whirlpool MH7130XE Microwave Oven
Cooktop light quit working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 20, 2008 | Whirlpool MH1140XM Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
