Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Samsung HLT5055WX/XAA-Usually the TV pops and then people sound like they have inhaled Helium. Also seems to be a bit of an echo. Sometimes the audio is distorted for an hour or more and sometimes less. We are on Charter TV system with the receiver box connected to the TV through HDMI cable. I have done a reset of the cable box(Unplug and wait a couple minutes), and the audio system through the remote menus. Any suggestions or help would be greatly appreciated. Carlcmats52@gmail.com
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on May 31, 2017
techman
  • 3130 Answers
SOURCE: TV pops and shuts off
Its two maybe three issues that your having trouble with. First thing is the convergence. That problem could be a cold solder connection on the convergence IC's or the Ic's have a thermal problem, as after they heat up they go bad. The second is the popping. This could be an issue with the rear channel Audio output Ic intermittanly shorting and shutting down the set, or it could be a bad ground around the picture tubes, or a leaky hi voltage block, or a second anode lead going to the picture tubes could be split. The other common problem with this set is the STR#### regulator IC in the power supply. Now unless your a tech you shouldnt attempt any of these repairs as there is very high voltage in this set and could cause great harm to you. seek the help of an authorized repair shop for Toshiba. Try this # if you cant find one in your area 800-457-7777 Good Luck
Posted on Jun 09, 2006
SOURCE: No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Posted on Dec 31, 2007
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
SOURCE: I have no audio on my 42" Samsung plasma tv
This happened to me also. It had to be taken apart. The audio connector on the motherboard had come lose. Hope this helps.
Posted on Feb 07, 2008
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Posted on Mar 29, 2008
SAMSUNG dlp tv wont come on..trys too them goes off before pic appears and flashes red and green light not light in middle..model is HLT5055WX/XAA
There are so many possibilities... If you are SURE that the lamp is good (did you take it out & look at it?) Easiest: When you turn on the tv, do you hear a 'whirring' sound coming from the back? If you do, is it a 'smooth' sound or is it rough, scratch, & noisy?. If it is smooth, or if there is no sound, next place to check is the power supply. If it is rough & noisy, it is a bad color wheel. Unless you REALLY know what you are doing, anything other than a lamp replacement should be left to a professional repair person.
Samuel Morris
Camtek Of NY Inc
Oct 12, 2014 | Samsung Hlt5055w
HLT5055WX/XAA Has intermitant sound distortion
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
May 12, 2014 | Televison & Video
Pb01 HLT5055wx/xaa Has 9 dots on screen small pinpoints All over randomly
Sounds like panel fault. Anyway, http://electronicshelponline.blogspot.com/ check this link. There is details and screen shots to defects to flat panel TV screens. Compare the screenshots with your TVs, and make sure about the fault. Pull up older posts.
Jun 15, 2013 | Samsung Televison & Video
I have a Model HLT5055WX/XAA that will turn on, but shortly after coming on the picture goes out. Audio still works but picture goes out and the lamp turns off. I think i need to replace the lamp but am...
Sometimes you have to gamble, lamp most likely--at least look at the lamp and make sure the glass pillar in it is not at a angle etc.
Sounds like you have taken all the easy steps, hate to buy a lamp you may or may not need but since wheel is ok the lamp or ballast are most likely.
Dec 16, 2012 | Samsung DLP HL-P5663W 56" TV
HLT5055WX/XAA turns on then turns off. About 2000 hrs on Philips replacement bulb
That is near or past the normal life on the lamp---2,000 hours or 2 years is normal---I would remove and look at the lamp---if shattered you know and also look the pillar of glass inside the lamp is not bent or warped etc.
Dec 06, 2012 | Samsung HLT5055S 50" TV
Samsung HLR4667WAX/XAA made a loud popping sound, picture went out and then the sound
Your lamp is burnt definitely (lamp makes that sound ,take lamp out and You will see inside lamp) no sound ,because unit goes to protect mode and shouts down power
Aug 08, 2011 | Samsung - Lamp for Samsung HLR4667WAX/XAA...
Have a DLP DNIe model nbr HLN4365WX/XAA tv that has begun popping white lights when the tv has been on a while. What does that indicated?
Hi my name is Roety,
I can help you with your issue ,
If your TV pops the lamp if may be overheating
Clean all fans and vents with compressed air
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 28, 2009 | Samsung Televison & Video
When vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
