Question about Samsung RF266AE (260 cu ft) Refrigerator
Sumsung rf266 fan noise - Samsung RF266AE (260 cu ft) Refrigerator
  • Samsung Master
  • 5,323 Answers
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Posted on Apr 10, 2015
How do I remove flapper bar left French door Samsung RF266 fridge to replace gasket? Thank you
here is the manual on removing the doors. This will show you how to remove the door, then replace. http://downloadcenter.samsung.com/content/UM/200909/20090913021004593/DA68-01812H_RF266_RF263.pdf
Sep 20, 2016 | Samsung Refrigerators
THe filter light will not go out on our Samsung RF266.
If memory serves, you put your finger on & hold the filter warning indicator for 3+ seconds and that will reset it after the filter is replaced. I've temporarily misplaced my owner's manual to confirm for certain.
Sep 08, 2014 | Samsung Refrigerators
Rf266
Clean coils underneath
Sep 02, 2014 | Refrigerators
Freezer problem
Pull out the freezer door & drawer. Check in the back, up high and you'll see a cover for your freezer evaporation controller (fan). There's a cute, quiet little fan up there that circulates the cold air when the door closes; it has probably failed on you. Without it, the icemaker quits/faults out, you get a lot of frost and generally a poor attitude towards the company; which I can't blame you. Luckily, we had the warranty AND the right tech showed up after six tries. Thought I'd get a new one after two tries but they snaked their way out of that and I have a worked freezer again.
Jul 12, 2010 | Samsung RF265AA Bottom Freezer French Door...
Sumsung Digital Camera, Pics are showing up with white fine lines running through them on preview. And the pic's don't even show up when connected to the PC to import.. Pliz Help Its a Samsung, S630
Often called "digital noise" , the lines are a symptom of an aging screen or screen electronics.... or water damage.... good luck
Oct 12, 2009 | Cameras
I have an sumsung ac m#aw1403b 13,800 btu the lc indicator turn on but the air doesn't no fan or nothing but the lc shows speed,temp,funtions.etc but no air please can u help
it could be a fan motor or capacitor fault.Could be something jaming the fan blade.Does the compressor start? If you have nothing working then it is prob a problem with the control unit
May 02, 2009 | Samsung AW1403B Air Conditioner
Whizzing noise
Need to check both of them.
-- open the back cover & unplugged two socket for cooling fan.
If still noise there, need to exchange the color wheel.
Jan 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung RF266AE (260 cu ft) Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
