Question about Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens
Lens will only zoom in the range 24 - 40mm. There is a mechanical problem inside which prevents it zooming out to 18mm and in to 70mm.
    Sergeant:
  • 291 Answers
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Posted on Apr 06, 2010
Zooming from 18mm to 55m causes lens to darken (pictures taken are the same). This happens in both M and AF.
This is because the aperture varies with the focal length. Note the "f/3.5-5.6" in the lens designation? This means that the maximum aperture is f/3.5 at 18mm and f/5.6 at 55mm. If you set the aperture first and then zoom, the aperture could change by as much as one-and-a-third stops.
To prevent this, zoom first and then meter the exposure.
Aug 13, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d3000 blurred photos
You may be trying to hand-hold the camera in situations that call for a long shutter opening. These are usually indoor situations with with limited light, dark walls, etc or night time shots. To get an idea about the longest time you can hold a camera by hand with creating blurred pictures (without a tripod or other stable mount), look that the focal length of the lens. If it is a a zoom lens, this value changes depending on how far zoomed in or out you are. A 70mm-300mm zoom would have a focal length of 70 if zoomed out or widest, 300 if zoom in or narrowest or something between 70 and 300 if your not fully zoomed in or out. The lends will have indications as about the focal length you're current at. If it is not a zoom lens, it is a fixed or prime lens. You can only shoot at the focal length of the lens. Typical primes are 35, 50, 60, 85, 100, 105 etc. (but there are many more). Once you've determined what the focal length is, multiply by 1.5 (for DX sized sensors like the D3000 and others; FX bodies and 35mm film cameras skip this step of multiplying by a factor of 1.5). Let's assume you've got either a 50mm prime or an 18mm - 70mm zoom lens currently zoomed to 50mm. With the info above, 50 x 1.5 = 75. Next, find the reciprocal which is simple to do - just make it a fraction with a 1 on top, like this: 1/75. This fraction is the longest length of time in seconds that most people can hold a camera before shake appears in the captured image. The shorter the focal length or wider the shot, the longer it takes for the shake to be noticeable in the captured image. A few more examples follow: When the 18mm - 70mm lens is zoomed in to 20mm x 1.5 = 30; or 1/30 sec, when a 80mm-300mm lens is zoomed in at 100, 200 or more, that time plummets quickly: 200mm x 1.5 = 300; or 1/300 sec. 300mm x 1.5 = 450; or 1/450 sec. Use of a tripod, monopod, or other bracing is highly recommended. Additionally, you can try opening the aperture wider (a lower f stop number) and / or increasing the ISO value to 200, 400, 800 or more. The drawback to increasing the ISO is the introduction of digital "noise" or graininess. How much graininess that is acceptable is something only you can decide. Experiment by taking a number of pictures of the same subject (preferably with the camera on a tripod or table top) with a range of different ISO settings. Look at the results on a large screen - like your computer monitor - to get an idea about how the graininess or noise increases with each bump up of ISO. You will probably find that once you get to a certain value, it's not worth taking pictures. This will be your no go value - and you'll want to shoot at a lower ISO than this. it is not uncommon for this number to be as low as 200 or 400 with P&S (point a shoot) cameras and 800 on some entry and mid range dSLRs like your D3000 to as high as 3200 (or even more) on some higher end prosumer / professional bodies.
You may also be having an issue with focus. If you have turned AF (auto focus) off, you'll have to focus manually. If you have AF on, but do not hear the focus motor in the lens - there could be a problem with the lens. Try removing and reaseting the lens on the camera body again. Try other lenses to determine if it is lens specific or camera body specific. Also, if there isn't enough contrast in the subject, the lens will not be able to find focus. Check again taking pictures of well lit subjects. You may find that your lens will not open wide enough to reduce exposure time. This is where the expensive f1.2, f1.8 and upwards to f2.8 shine. They gather 2, 3 or 4 times as much light in the same time as a f5.6 lens can. The drawback to these lenses is their cost.
I hope this helps and good luck! Please rate my reply, thanks.
Feb 09, 2012 | Nikon D3000 Digital Camera
How do I access the macro function on the nikor 35- 70 1:2.8 D Lens?
Pull the lens all the way IN (i.e. zoom to 70mm) then press the MACRO LOCK, and then adjust focus using the macro ring.
Feb 08, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Someone asked me to take photos with my Nikon D90. I have the 18-105mm lens that I got with it. Is this able to take 'wide angle' photos?? I know there are special lenses made specifically for wide...
The 18-105mm lens at the 18mm end of the zoom range is a pretty fair wide-angle lens. Look through the viewfinder and turn the zoom ring (the big wide ring at the front of the lens) one way and then the other. The 105mm end is the view that looks like you're using binoculars, the 18mm end is the view that looks like you're using binoculars backward.
Oct 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
The zoom ring has limited use...maybe something stuck inside lens
If you are unable to maximize the zoom capabalities of your lens, the mechanical gears might have been jammed and or broken. Do not push it if it won't let you as you might break the lense. What you can do is to bring it to your local camera shop or service center to have it fixed.
Jun 09, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Is there a chart that explains the range of a lens. I have a Canon EOS and want to buy a zoom lens to shoot birds, wildlife etc. I don't know how far80-200 MM shoots. I know it's sounds like a dumb ?'s -...
Multiply the mm by 1.5 to get the actual range on a digital camera for any particular lens. Example...80-200 is actually 120-300mm. Then, to give you an idea of how that will look, every 50mm is like a 1x power on a pair of binoculars. Example...120=2.4 power, 300=6 power.
Sep 22, 2009 | Canon Digital Rebel / EOS-300D Digital...
My 18-70mm DX has a shaky front portion that the shade fits on
My lens did the same for most of the past year or so. Finally it started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)!
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Mar 20, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Friction in zoom, Sigma AF 70-300mm for Canon-EOS
Its more like a distorted inner zoom barrel or sand and dirt inside  the inner barrel will need to be replaced or you need to dismantle and clean out
Nov 09, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens Logo
214 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
