Question about Samsung Washing Machines
Samsung p801 what does E6 mean?
5 Suggested Answers
  • 3 Answers
SOURCE: I have a samsung sensor
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
SOURCE: samsung p801 error code e6
were any of you guys able to fix this problem?
Posted on Sep 23, 2010
  • 6277 Answers
SOURCE: Samsung Front Loader P801 5
First the 'E6'. The only Manufacturer's decode I have for Samsung 'E6' is 'water temperature rising/ falling too quickly, check thermistor'. I would go through the balancing act (detailed below) and then see if it recurs. If so it's a service call I'm afraid ;-0(
Now the dancing
Although you say it's level I would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 07, 2011
  • 6277 Answers
SOURCE: Hi I have a samsung model
Although you say it's level I would really recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 09, 2011
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
Samsung Front Loader P801 5 years old - bangs and dances during spin even at low speed get error message E6 when it cuts out. No mention of E6 error in manual. Troubleshooting section of manual of no help....
Now the dancing
Good luck,
John C
Apr 07, 2011 | Samsung Washing Machines
I have a samsung sensor quick P801 800 front loading washing machine. It is giving me error code E6. Is this an easy fix?
Sep 14, 2010 | Samsung Washing Machines
Where do you get parts for Samsung p801 washing machines?
Any repair company on here answering queston for samsung appliances could help you in some way
give one of them a call or do a search in your local area.
example : go to google or yahoo and type samsung washer parts (((( your area )))) (((( your state )))
May 24, 2010 | Washing Machines
Model p801 frontload, it walk all over when in
sounds like your machine is unlevel have you taken a level to the machine and the floor and checked both , they should never walk unless they are unlevel
Dec 30, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung p801 error code e6
Oct 23, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
