Question about Husqvarna Garden
322l weed trimmer will only run with choke ? - Husqvarna Garden
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
Posted on May 31, 2009
#1 Taper
  • 1040 Answers
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
  • 62 Answers
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Posted on Sep 25, 2009
SOURCE: The trimmer starts like a dream but only runs with choke on
sounds like the carb needs to be removed and cleaned. It the chunk of metal that has the fuel line going to it on top of the engine.
Use a phillip screwdriver and possible a small ratchet to break it down and clean it thuroghly with gasoline.
After you get it back together and have cleaned it up as much as possible, crack her up with full choke again. this time though, allow it to run and barely ramp up the rpms enough to give it a little lug. When the engine seems to begin losing power, (these adjustments should be as small as possible until you get her running smooth) dial the choke back just enough to ramp up the rpms. This will probably take a few tries, but most definately should work in your case.
Once the trimmer is running smooth with the choke off you will be good to go.
Many times our trimmers and other 2cycle engines dont get the proper attention to keep them running up to par. Take the time to consider the unique properties of your tools to determine any possible future repair. Anytime you have and engine that burns a home mixed fuel there will be the risk of trash in the fuel system
GOOD LUCK AND PLS RATE THIS POST!!!! :D
Posted on Jun 03, 2010
hunter19_46m
  • 7482 Answers
SOURCE: have a troy built tb
Sounds like you will need to clean your carburetor. Sounds like you have gotten some trash in the cauburetor, check your fuel container to see if more trash is in it.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why will My weed eater only run with the choke fully on and cant give throttle?
    It sounds like the carb needs adjusted. Things can even happen to new weed eaters.
    May 31, 2014 | Poulan P4500F 16-Inch Straight Shaft 25cc...
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Ryobi weed eater runs at full choke, but stalls when choke is turned to run position
    does it blow out alot of blue or dark exhaust? if so adjust screw on carberator as it maybe be running rich, if this doesnt work have the switch checked for malfunctioning
    May 30, 2010 | Ryobi 15" Electric Factory Reconditioned...
    Poulan ppb 250 weed eater, only runs with choke on,
    Sep 20, 2009 | Garden
    Garden Logo
    42 people viewed this question
    Top Husqvarna Garden Experts
    Phil Walker
    Phil Walker
    Roland W VanLue
    Roland W VanLue
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
