Question about Xerox DocuPrint C525A Laser Printer
Xerox c525a error close frontcover after replacing cartridge
Suspect front cover broken switch how to access and repair or replace
  • 2072 Answers
SOURCE: Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
Posted on May 15, 2009
  • 30 Answers
SOURCE: why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Posted on Jun 08, 2009
  • 2072 Answers
SOURCE: Xerox - replacement toner cartridge problem
Not that I know of. Did you receive a chip with the toner? If not that chip would need replaced to reset the counter;
Posted on Feb 22, 2010
  • 217 Answers
SOURCE: Xerox 6180 MFP's cyan cartridge isn't recognized
There are a number of possible causes of this.
1. Faulty chip on the cartridge, or badly fitted chip.
It will look obviously 'odd' if the chip is incorrectly fitted to such an extent that contact cannot be made between the cartridge chip and the printer. If it looks OK, and you still have the old cartridge, try swapping the chip (complete in its 'carrier') from the new one onto it. If the stays, it's the chip. Confirm this by putting the OLD chip back on the OLD cartridge, and you should get a different message telling you the catridge is empty.
2 Broken cartridge (I've seen quite a few like this - see pictures - the broken one had probably been dropped).
First picture - undamaged cartridge, note 'lug'.
Second picture - missing 'lug' (cartridge has probably ben dropped)
There is an opto sensor that checks the presence of the cartridge by 'looking for' this lug. The matching one at the other end of the cartridge has no effect.
It is possible to glue a broken lug back onto the cartridge, if the lug is missing, make something that matches the overall size and profile and glue that on - make sure the glue has set/hardened fully before putting the cartridge into the printer.
3 Faulty circuit board, or sensor in printer.
If you've tried the instructions under 1, and the error message stays the same through all the combinations of OLD chip, OLD cartridge, NEW chip, NEW cartridge, AND 2 is not applicable, this is where you are. It could be the opto sensor that 'looks' for the cartridge - you could 'short' this out (be careful to do this on the correct side of the device). Otherwise its a circuit board problem.
Posted on Apr 15, 2010
  • 16 Answers
SOURCE: I vacuumed all the dust from my c525a including
Clean inside printer using cleaning rod. Open front cover, pull out lever on right side to open access window on right side (outside) of printer. Pull out and push in cleaning rod several times.
Posted on Dec 13, 2010
How can i repair phaser without frontcover
One way would be to take the front cover from the OKI B2540 machine (they are identical). If that isn't possible you would need to make a jig to hold in the interlock microswitch, a restraint to keep the cartridge from moving, and a light sheild to prevent light from entering the cartridge cavity.
Jun 26, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Unable to close Cover E of Fuji Xerox c525a
For anyone smashing their head against the wall about this problem I finally found out what the issue is in regards to the C525A Cover E not closing.
If you run into this issue you need to look inside the printer where Cover E is, at the very bottom of this is a piece which looks like the rest of the printer but actually freely moves up and down on a swivel. Put it in the up position and as you go to close it it'll fall down again but this time Cover E will close. Not banging it shut or punching it, it all clicks back into place nicely.
Nov 19, 2011 | Xerox DocuPrint C525A Laser Printer
How to replace toner cartridge in xerox 525A
Problem with the Xerox DocuPrint C525A Laser Printer How to replace toner cartridge in xerox 525A ' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "2438490332+4447185069+1147946396"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Dec 19, 2010 | Xerox DocuPrint C525A Laser Printer
Apr 07, 2010 | Xerox DocuPrint C525A Laser Printer
HP 4600 printer shows all cartridges OK and the print quality adjustment for all colors is set at 0. Have calibrated and adjusted color. Yellow does not print Pages come out in pinks
Try a new cartridge. If this doesn't solve the problem then check the lens cover of the yellow printhead. It should open when you close the front cover. You can check it by taking out all the cartridges and than close the frontcover slowly. Watch the lenscovers and check if they are opening when you close the front cover. Good luck, Gerrit Jan
Oct 29, 2009 | HP LaserJet 4600dn Color Printer
Fuju Xerox C525a not printing right edge
Clean the inside of the printer using the cleaning rod. See page 48 of the user manual.
Open front cover,
Pull out lever on the right side. This opens the access window cover on the right side of the printer.
Inside this access window is the cleaning rod handle. Pull it out and push it back in several times to clean printer.
When done push the rod back in and push the lever on the front right panel back in. Close the front cover and you're done.
Do this every time you replace the black toner.
Jun 29, 2009 | Xerox DocuPrint C525A Laser Printer
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Print cartridge "missing"--NOT
Problem:
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Door A not closed properly. - Open and close door A, then power cycle the printer and check for the error again.
2. The rails that the print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all print drums, then check and re-align print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
TROUBLESHOOTING TIPS AND HINTS:
Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
Apr 01, 2008 | Xerox Phaser 7700 Laser Printer
Xerox DocuPrint C525A Laser Printer Logo
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
