Question about Toshiba E-Studio 282 estudio 282
C410 errer. showing C410. already we are apply 8 0 then 4 0 0 then test 0 0 then switch off. now showing C410. what solution for C410.
    Champion:
    New Friend:
  • Toshiba Expert
  • 253 Answers
Replace Thermistor
Posted on Jun 26, 2016
3 Suggested Answers
fivemayur
  • 414 Answers
SOURCE: Toshiba e-studio 352 error code c410
08 on 400 set 0
Posted on Aug 17, 2012
fivemayur
  • 414 Answers
SOURCE: it says c410 ?
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Posted on Aug 23, 2012
Toshiba 2303A Coll for service C447
fuser related problem but try out this Check if the connectors are disconnected.
(2) Check if the center, side and edge thermistors are in contact with the surface of the fuser roller
properly?
(3) Check if the harnesses of the center, side and edge thermistors are open circuited.
2. Check the heater
(1) Check if the heater is broken.
(2) Check if the connector of the heater is disconnected.
(1) Check if the connectors CN308 are disconnected.
4. Clear the status counter
After repairing the matter which caused the error [C410], perform the following:
(1) Turn ON the power while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press [START].
(3) Change the current status counter value "1" or "2" to "0", then press [ENTER] or [INTERRUPT]
(to cancel [C410]).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal ready
Jan 21, 2018 | Toshiba Office Equipment & Supplies
How to remove input tray hp photoxmart c410
There really is noway of removing paper input tray on C410 printers. Are ou talking about the Scanner feeder tray? That one just pulls out by lifting up and down as you pull to your right if you are looking at the pinter.
Jun 04, 2017 | HP Office Equipment & Supplies
Toshiba e 233 is error code C410 how to clear
Thermistor or heater abnormality at power-ON
(to cancel [C410]).
state.
Jun 25, 2016 | Toshiba Office Equipment & Supplies
C 41 code mean
I suppose the error code is C410.
To clear the error message, perform 08-400 => 0.
If happen again, u need to check the themistor.
Oct 03, 2013 | Toshiba Office Equipment & Supplies
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
Error c410 toshiba estudio 455
properly?
then do this steps :
(to cancel [C410]).
Jan 03, 2012 | Toshiba e-studio 455 Copier
Studio 3511 tiene error c-410
Error C410 indicates Thermistor or heater abnormality at power ON.
What u can do:
(2) Key in “400”, then press the [START] button.
(3) Change the current status counter value “1” or “2” to “0”, then press the [ENTER] button or
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal ready state.
If happen again, u need to check followings:
thermistors, IH control board and IH coil, LGC board.
Jul 27, 2009 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 282 estudio 282 Logo
119 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
