Question about Video Cameras
Jvc digitial theatre system th-d60 wont turn back on after turning off
  • 238 Answers
SOURCE: JVC TH-A30
hi, check out this link, ,browse thru the page, you will find your model in the list, let ,me know..
http://www.ssrichardmontgomery.com/dvd_unlock/dvd_unlock_ijkl.htm
Posted on Dec 19, 2007
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
  • 84 Answers
SOURCE: JVC TH-S3 System
try to check the av output wire if its properly connected according to its color.
Posted on Jul 21, 2008
SOURCE: home theater system jvc th-d60
This is from the TH-D50 User Manual:
The connected TV is not HDCP-compatible. (“HDCP ERR” appears on the display.)
Disconnect the HDMI cable and connect it again, or use a shorter cable.
Posted on Dec 31, 2008
ginko
  • 19396 Answers
SOURCE: JVC TH-C30 Digital Theater System
If there is no power at all, then try bypassing surge protector, check power cable, and check if power cord is fused.
If unit has power but does not start, then it is on protection.
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
How do I get a disc jammed out of my JVC theatre digital TH-C5 theatre system step by step?
I can't see any procedure for removing any disc. So your best option is to open the unit containing the disc up and remove it manually. If your lucky you should see a belt that will slide the drawer out. If you have doubts then take it to the nearest JVC repair shop.
Nov 25, 2016 | JVC TH-C5 System
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
Where to purchase a subwoofer for my Jvc home theatre
You can get a complete refurbished JVC TH-A25 System on Amazon for $130. Individual components might be scarce or prohibitively expensive.
May 23, 2010 | JVC TH-A25 System
Sounds cuts out if volume is over 30
hey
I have been has same problem for long time, actually problem was on and off... the reason was short circuit of speakers or speaker connections.
I find a little peace of cable stack inside of the connection handle. you know all the cable stick on back...
well what you can do is, unscrew all the screw back and the bottom of the box. slice the electronic box, just check connection piece is clean cable free....
use always clean cable and don't put it too much.
it is very easy to fix
http://www.myfixtips.com/blog/av-receiverhome-theatre/no-sound-from-jvc-th-m303-home-theatre-system-456.htm
Oct 11, 2009 | JVC TH-M303 System
Hooking up my ps3 to a all in one jvc home theatre system
Well I am assuming that you have a HD tv, If so than you can run HDMI from Ps3 to Tv then run optical audio wire from ps3 to reciever.To listen to ps3 turn reciever to aux setting.
Hope this helps
Apr 29, 2009 | JVC TH-G30 Theater System
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Video Cameras Logo
13 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
