Question about Grilling
Removing burner from Kirkland 720-0011
How do I remove the burners from the Kirkland 720-0011 grill? I know that there is a screw with a nut, but how do I get to the nut to loosen it? Do I need to take off the entire back of the grill?
SOURCE: burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Posted on Oct 26, 2008
  • 9 Answers
SOURCE: gas burners heat unevenly
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Posted on Jun 26, 2009
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
ShirtK
SOURCE: replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Posted on Jun 29, 2009
SOURCE: having trouble changing 3 steel pipe burners on Charmglow grill
The best way to install these burners is to get a vice grip/pliers and bend the end of the burner where the screws can be placed. If you notice on that end there appears to be a section where it will bend without impacting the integrity of the burner itself. It will bend enough for you to place the burner in its place. Once installed, bend back and screw in the screws to hold in place.
Posted on Feb 26, 2010
How to change burner on kirkland 720 gas grill
You should not need any special tools. The burners are usually held in place with screws If you take the top grills off, there may be a set of covers or shrouds over the burner unit. They usually just lift out. After you have removed those covers, study the burner unit and locate the screws, which are uasusally in the front.Lift the front of the burner and the back of the burner should come out with a little twist.
May 31, 2014 | Costco Kirkland Grilling
How do I remove burner tubes on summit gold
The burner ends (the tips farthest from you) are either held in place with a sheet metal screw or the tip fits it a small slot. Either way, removing the burners is the same. If it has a sheet metal screw - remove the screw and lift the burner up and toward the back of the grill. While lifting the burner, pull if away from the front of the grill, so that it slides off the the venturi valve and the burner will lift out.
That's about all there is to it. To help you further, I have included a link to your Owners Manual, that you can download and print for future reference.
http://www.weber.com/help/manuals/pdf_files/Summit_Gold_D_NG_41996_03_27_03_Revised.pdf
Happy Grilling!!
Apr 07, 2011 | Weber Summit Gold D6 (NG) Grill
How do I install replacement burners for my Charmglow 720-0036-hd-05 grill
Replacing Burners on Charmglow 720-0036-HD-05.
1. Disconnect the gas line to the "side burner".
2. Remove the two "side shelves", each of which is held on by 4 large phillips screws.
3. Remove the "control panel" that is held on by two smaller phillips screws at each side of the "control panel".
4. Remove the "front baffle" located directly behind the "control panel that is held on by 4 phillips screws.
5. Lift off the "cooking grills" and the "flame tamers" (the plates over the burners) so that you can see the burners.
6. Now you can slide each of the burners forward and then left them out of the grill.
Replace everything in the reverse order.
Apr 07, 2010 | Grilling
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
How do i go about replacing the middle burner on my Ducane bbq, model number 30400046? I have already ordered the part.
Remove the cooking grate so you will have unrestricted access, remove the flame tamer (it should be able to come up without effort) to expose the burner. At the back of the grill there is a screw that attaches the back part of the burner to the grill. Remove the screw, then grip the burner and pull it towards the back of the grill, this should release it from the gas valve in the front. To put the new burner in, just do all these steps in reverse...let me know if this works for you, if not I can walk you through it via chat.
Sep 24, 2009 | Ducane 30400040 Stainless Steel Grill
Having trouble changing 3 steel pipe burners on Charmglow grill
Sep 09, 2009 | Grilling
Apr 16, 2009 | Ducane 30400042 (LP)
TECH II CERAMIC BURNER PROBLEM
just removed ceramic burners on my patio II-had to grind heads off of stainless stee bolts[ 4 on each burner],bolts do not have nuts instead they have theaded collers which have deteriorated and turn when i turned the bolt.used a 4" angle grinder-remove gas cylinder before attempting this!
Apr 11, 2009 | Tec Patio II Grill
Burner replacement on Ducane 30400040
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Grilling Logo
95 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
