Question about C3RS6652W
Where and how do i locate the sim id on my autopage product......
Is it possisble to include pictures.. i got to the main brain in the dash and didnt see any card?? please help
I loss my sim I'd number for my C3 - RS - 665 autopage alarm
If the alarm brain does not have a sticker with the ID number than you will have to pull the SIM card out. The SIM card will have the ID number imprinted on it.
Sep 04, 2012 | C3RS6652W
I need a replacement remote XT-43LCD FCC ID:H45OTR29
you can contact autopage's authorized remote replacement services at www.autopageusa.com and clicking need a replacement transmitter.
Jan 12, 2011 | C3RS6652W
The lights no longer blink when unlocking and do not come on when starting
you will need to check the fuse, located on the 5 pin harness at the main brain. It is white in color.
Dec 26, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
For the viper 791xv where is the enternal battery is it under the hood or inder the steering wheel
If you disconnect your main battery then the viper won't work Or if you find the brain under the dash you can pull the 10 amp fuse which is the power for the brain.
There will also be three 30 amp fuses, but they don't power the brain, they are just for remote start part.
Aug 14, 2010 | Viper Security and Remote Start System...
I have the autopage rs730 alarm with the c3 ups module? My problem is that I cent control my car from either laptop or cell phone? I can locate it with no problem but cannot control it from either device?
You will need to verify the DATA cable is plugged into PORT B on the main unit. This is essential for correct communication between the 730 and the C3 unit.
Jun 28, 2010 | RS730LCD REMOTE START 2WAY SECURITY SYSTEM
Kenwood KVT-817 brain, Is the brain needed or can I use without?
Not much you can do my friend , I tried locating and using my resources to find you a Brain and it looks like its discontinued, Im sorry to say but this guy played you, he sold you the head unit without the brain, its really messed when people take advantage of honest people like yourself. Try ebay here and there if not your just going to have to upgrade my friend, sorry.
Good luck,
Lex..
May 23, 2010 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
How to turn off the alarm because its goes on for any reason
Hello , most car alarms have a brain box located under the dash plugged in between your fuse box or ECU and the main large wire harness under the dash above the steering shaft. You can unlpug and remove this brain and attach the original ends from the car back together. You will no longer have an alarm , but this will stop it from always going off as it will not be in the car.
Mar 13, 2010 | 1997 Mazda Millenia
I can't find a valet switch for my python 460hp?
you can find the "brain" by tracing the wire from the LED blinking light to the brain than look for a grey and black wire which is the valet switch. Don't look for a toggle switch either, your looking for a little black button not a silver toggle but a little black button. Depending what vehicle you have also matters, for instance if you have a GM truck look in the side dash fuse panel or look BEHIND the hood latch handle. It's a ***** to find sometime but essential that you know both where it is and what it does and how it works.
Aug 08, 2009 | 460HP Security System
I have the Clarion VRX936VD head unit but ineed the brain+cables
Do you still need the brain? I used to have the VRX935vd in my car, and it was awesome! Someone broke into my car and stole the in-dash headunit for it, but they didnt steal the brain that was below my driver's seat. I still got the brain and all the cables if you're interested. email me at db85@inbox.ru
Nov 13, 2008 | Clarion VRX935VD Car DVD Player
C3RS6652W Logo
44 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
