Question about Apple iPhone Smartphone
I have an iPhone 3g 16giga, please help... all else is working but the phone (to call) menu, the touchscreen is not reponding.. please, please help me.... :(
Did you jailbreak your iphone? If so, did you recently install something from Installer? Probably...a Kate? That software is very buggy, and caused most of the problem with the phone app in iPhone. Hope that helps.
Posted on Jun 23, 2009
My iphone touch pad will not repond and I can't power off or login in.
Sounds like your phones digitizer (glass part) has gone dead. Try getting it replaced.
Tony
iRefresh, iPod repair service
Feb 27, 2013 | Apple iPhone 3G
I have tried to restart my i phone 3g but touchscreen still wont work have you any ideas what i could try to fix this
Sorry to read about your problem, I hope this helps you out.
their is nothing you can do, if under warranty take to apple, if not you can do a trade in for a phone,
or last but not least, send to a internet repair service...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Apple iPhone 3G
Menu bar at bottom of screen does not repond during normal use ie unable access menu to make call etc but works when i use the slider to unlock the phone when turning it on . what is the problem and how...
sometimes its just running a little slow... try hard reseting it. hold the power button, and the home button at the same time for about 10 seconds. :) then power it back up!
Jan 30, 2010 | Apple iPhone 3G
Is a 2g touchscreen compatible with a first gen Iphone? Will it work if I buy the part on my 1gen phone?
Do you mean a replacement glass to put on your 1st gen iPhone? It can get a bit confusing with the 'Generation' labelling, as 2G in fact refers to 1st Generation iPhones (any prior to the 3G, hence 2G - it relates to the data connection protocol more than the hardware version).
So, with that in mind - am I correct in assuming that you have seen a 2G screen for sale?
If so then yes it will work on your 1st Gen (2G) iPhone. I haven't compared the 2G/3G screens that closely, but I do know some of the sensors are located in a slightly different position on the 3G which may in itself be an issue.
Let me know if you want me to further investigate and I'll help if I can!
Oct 28, 2009 | Apple iPhone Smartphone
The touch screen on my iphone 3g wont work
This is what you should do:
Press and hold both the power and the home button until the Apple logo comes up. Release the buttons at that point.
That way, you will force restart your device and it should respond to your touch.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Aug 05, 2009 | Apple iPhone 3G
Iphone keypad not working
First try a hard reset. Hold down the power and home button simultaneously for 10 seconds until the iPhone reboots.
If that doesn't work you need a new digitizer. If it's a 3G I would advise replacing the digitizer. If it's a 2G I would not advise replacing the digitizer b/c you would have to replace the LCD, Digitizer, and the Glass Panel and the cost would exceed $100.
You could also consider selling your iPhone AS IS for parts or repair on eBay, Craigslist, BuyMyTronics.com or I could make you an offer.
Hope this helps, Rate me please!
Jun 17, 2009 | Apple iPhone Smartphone
Dropped iphone with WHITE Screen
Hi
There might be a Flex cable that disconnected in the phone, you will need to bring it to a cell phone shop or apple to have a look at it.
David
CellUnlock.net
Feb 25, 2009 | Apple iPhone 3G Black Smartphone
Battery drain out in 2-3hrs just on standbymode!!!!!!!!!!
I would upgrade to the latest firmware, it seems it saves battery. Also, is your phone on full lightning, if so, put it lower. If it still does that, maybe you have killed your battery by recharging it too much, or leaving it on the charge too frequently. That kills the battery's life. If thats the case, you'll need to get a new battery from apple, and it's expensive.
Oct 07, 2008 | Apple iPhone 3G
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
