Question about Sony Ericsson W760i Cellular Phone
Assingning a ring tone to a person
I have purchase sony w760i, please help me how to assign a tone to a particular person
    Problem Solver:
Go to contacts and select one. Then press options and edit contacts. Then move to the right and u will see picture and ringtone. Then u select ur ringtone.
Posted on Jun 30, 2009
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
I dont find stored songs when i them for assigning ring tone to a particular number and assigning songs to alarms. I only find default songs stored on phone memory.
pls put songs in digital folder and ringtones in simple folder. dont change that again..now assign it..u wil get it right..!!
Jun 16, 2010 | Nokia N73 Cellular Phone
How do I assign ringtones to particular people? Thanks
select a particular contact,go to options and then select 'assign ring tone' and then assign the desired ringtones.
Dec 04, 2009 | LG Vu CU920 Cellular Phone
Assigning ring tones
hii
Inorder to assign a ringer id on Moto phones, Plz goto to contact of a particular person u want to assign thru phone book, U will find a an option RInger ID.
Note: This option shows up only if the contacts are saved in phone memory.
You can always refer ur phone manual. (if u dont have a manual then, you can download the eManual for phone)
Regards
Sep 06, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Ringtone not working
u need to go contacat list then
contact seting and then u get a option of image used as wel as ringtone used or assin tone then u can set specific tone for each number..
Mar 02, 2009 | Sony Ericsson K790i Cellular Phone
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Jan 13, 2009 | Avaya 4610SW
How can I block a number on my iphone?
A lot depends on your model of phone.
My phone I can assign a specific ring tone to each phone #. So annoying numbers I have assigned them as a Mute ring tone.
When you edit a phone number, it should give you options as to blocking, assigning a ring tone, saving etc.
Please rate this solution
Jul 31, 2008 | Cell Phones
Ringtone problem
You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
1) First save the specific number
2) Select the ring tone
3) Assign the this ring tone for that number
This information help to you othere wise refer your phone user manuals
Jun 11, 2008 | LG VX8300 Cellular Phone
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Sony Ericsson W760i Cellular Phone Logo
41 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
