Question about Vehicle Parts & Accessories
How to fix code p0731ford expedition 2005 - Vehicle Parts & Accessories
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Please note that these are just GUESSES from a shade tree mechanic . I do not claim to be a professional anything . Use my guesses at your own risk ! That being said , here is a place to start looking ...
Since the code refers to automatic transmissions , and gear ratios , I would certainly start by checking your car's transmission level . In most cars , the transmission fluid should be at full temperature . So , sometime , after you have been driving for 10 minutes or so , park somewhere LEVEL . Put the transmission in PARK . Pull the transmission dip stick , wipe it off with a paper towel , shop rag , or something appropriate . Reinsert it to the bottom . Pull it again , and read where the fluid level is .
If it is low , add the fluid SLOWLY . A PINT , or less at a time . Transmissions CAN be over filled . In MANY , if not most cars , the transmission fluid is added via the dip stick tube . ( This seems illogical to me , and you have to wait a while after every add , so the fluid drains fully out of the dip stick tube before you can get a good reading , but , OH WELL !!! )
GOOD LUCK !
Posted on Nov 08, 2014
I HAVE A 2005 FORD EXPEDITION THE PROBLEM IS A CODE P0420
http://www.ford-trucks.com/forums/1011390-06-expedition-xlt-p0420-code.html
Mar 17, 2015 | 2005 Ford Expedition XLT
P2004 intake valve stuck open
code p2004 refers to intake manifold air control actuator-bank 1--actuator stuck open===Causes---wiring--intake manifold air control actuator---mechanical fault .I would check blockage and wire connections Then I would replace the actuator But I would not tear down the engine as it is between the air filter and the manifold. Check the air cleaner element
Apr 27, 2013 | 2005 Ford Expedition
2005 Expedition - Changed battery and Cd changer won't work now, is there a fix?
I am not familiar with the 2005 Expedition CD changer, but many of the higher end devices require a code to be entered when the power is disconnected. This helps reduce the theft of car audio equipment since it can not be used again until the correct code is entered. Ford dealership can either enter the code for you or look up the code if you do not have the original manual for the CD changer which should have the code written somewhere in the first couple of pages.
Aug 19, 2012 | 2005 Ford Expedition
I have a 2005 ford expedition completely stopped in the middle of a highway error message check electronic engine throttle. please help
this is probably a relay or fuse issue unless youve had work done to your car or hit something . you should take it to autozone and have them run the obd2 scanner on your car and get the codes. write them down and let me know what they are or call your local ford dealer and talk to the service dept and tell them the codes and ask what the problem/cost/part numbers are. let me know after you do this and i will help to fix :)
Jan 11, 2011 | 2005 Ford Expedition
IDLE CONTROL SYSTEM CODE PO506
You need the idle control solenoid replaced. It is the dealer that will fix it for you.
Good luck.
Jan 02, 2010 | 2005 GMC Canyon
Check electronic throttle control
We have been experiencing same faults on a 2005 Expedition,with engine stopping and the message "Check electronic throttle". Ifirst went to AutoZone and they read the codes. They suggested replacing thethrottle sensor, which we did, but car stopped again. We had to replace thebattery in a month and this is the fix. The battery was almost 6 years old andwhen you first start your engine, it sucks too much load and gives these faultsto the computer. It never stopped since then (3 mo already). Sometimes we useto get the message 3 times a day.
Sep 22, 2009 | 2005 Ford Expedition
Reset the check engine light on 2005 Expedition
you have to take it to a shop to have it reset. if it tripped, it means something isn't working right, and that often leads to lower gas mileage if it isn't fixed, costing more money in the long term
Jan 24, 2009 | 2005 Ford Expedition
Vehicle Parts & Accessories Logo
56 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
