F8GVRZ how to check in
What 90,000 maintance needs to be done on 1998
Hyundai recommends the following service items for vehicles at 90000 miles:
  • Air Filter Replacement
  • Spark Plugs Replacement
  • Evaporative Canister Filter Replacement
  • Change Oil and Filter
  • Cooling System Flush
  • Rotate Tires
  • Check Brake, Steering and Suspension System
  • Check Parking Brake System
  • Check All Hoses
  • Check All Fluids
  • Check Exhaust System
  • Check Axle Shaft
  • Check Heating AC
  • Check Drive Belts
  • Check Power Steering System
  • Check Steering Gear
  • Check Gas Cap
  • Check Evaporation Emission System
  • Check Emission Control System
  • Check PCV Valve
May 15, 2014 | 1998 Hyundai Tiburon
Tip
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
90000 mile maintenance
Hyundai shows the following as a list of their recommended 90,000 mile maintenance items:
  • Rotate Tires
  • Check All Hoses
  • Check All Fluids
  • Check Axle Shaft
  • Check Heating AC
  • Check Drive Belts
  • Check Gas Cap
  • Check PCV Valve
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Hi, I own a Tyros 1 which gave me a lot of pleasure the past almost ten years. I installed a hard drive about a year ago and loaded a large number of extra arrangements. A problem developed recently. At...
Hi.
Try holding down the rightmost white key while powering up the keyboard. This is a minor system restoration, which may solve your problem.
Below is a way to run diagnostics as well >>>>
DIAGNOSTIC TEST:
if you think there might be something wrong with your board, you can have it perform several tests to see if all works well.
1. Power off
2. press C2# - F2 - G2# (all three together) and while keeping them depressed,
3. switch the power on.
You'll see the word "TEST" on the display
With Tempo - / + you can go to the test you want to perform. Start/Stop will start the test. Wait till a test is done!
You can check following items :
001 : Version
002 : Rom Check 1
003 : Ram Check 1
004 : flash Check 1
005 : Wave rom Check 1
006 : Effect ram Check
007 : TG 1 Check
014 : Pitch Check
015 : Output R Check
016 : Output L Check
019 : EQ low Check
020 : EQ mid Check
021 : EQ high Check
023 : Mute Check
025 : MIC Test (PSR3000)
027 : Sw, Led Check
028 : All panel led on Check
029 : Red led On Check
030 : green led On Check
033 : All LCD on Check
034 : All LCD off Check
036 : LCD Brightness Check
037 : LCD Pattern Check
040 : Pitbend wheel Check
041 : Moduration wheel Check
046 : Padal 1 Check
047 : Padal 2 Check
053 : Midi Check
055 : Video out NTSC RGB (PSR3000)
056 : Video out PAL RGB (PSR3000)
057 : USB To Device / Host Check
058 : USB Storage Device Check
059 : Card Check
061 : Keyboard Type Check
067 : Rom Check 2
068 : Ram Check 2
069 : flash Check 2
070 : Wave rom Check 2
071 : Effect ram Check 2
088 : Factory set
089 : Test End
When at 086, press Start/Stop to exit the test mode and your keyboard will continue to start up normally.
Good luck and regards.
Jan 01, 2013 | Computers & Internet
Preventative maintnance
Not knowing what you have done and when, below are the normal intervals for Checks and Replacements:
If you have not done something in a while, or can't remember when it was done: go ahead and do it now to keep your vehicle on schedule.
Every 250 miles: (Every Week)
Check Automatic Transmission Fluid Level.
Check Battery Electrolyte Level, Post and Connections
Check Brake Fluid Level.
Check Engine Oil Level.
Check Engine Level + Reservoir
Check Horn Function.
Check Operation(s) of ALL Lights.
Check Power Steering Fluid Level
Check Tires and Air Pressure Levels (Don't Forget the Spare)
Check Windshied Fluid Level
Every 3,000 miles: (Every 3 to 4 Months)
Change Oil and Filter.
Every 7,500 miles: (Every 6-months)
Rotate the Tires.
Check and Clean Battery
Check Cooling System Hoses & Connections for Leaks & Damage,
Check the Exhaust System.
Check the Condition of All Vacuum Hoses & Connections.
Check Wiper Blades. Replace if needed.
Check for "play" in Steering Linkages and Balljoints.
Every 9,000 miles: (Every 9-months)
Check the Brakes: Pads, Rotors, Calipers and Hoses.
Lubricate the Tie Rod Ends and Ball Joints.
Check the Drive Axles, CV Joint Boots: Inner and Outer.
Check Suspension: Coils, Struts and Shocks.
Every 15,000 miles: (Every Year)
Replace Air Filter
Change Automatic Fluid and Filter.
Check Fuel System Hoses & Lines and Connections.
Check Drivebelts/Surpentine Belts.
Every 30,000 miles: (Every 2-Years)
Drain and Replace the Engine Coolant Fluid
Flush Coolant System.
Check and Replace PVC Valve.
Replace Spark Plugs.
Replace Ignition Wires
Check Distributor/Electronic Ignition Coil.
Check Operation of ALL Seatbelts.
Check EVAP Emission System Hoses and Connections
Every 60,000 miles:
Replace Fuel Filter.
Let me know if this helped, or if you have any additional information or questions. Contact me at FixYa.com!
Mar 03, 2010 | 2002 Chrysler Voyager
What all should be replaced by 165,000 miles
Rotate the Tires.
Replace Air Filter
Every 60,000 miles:
Mar 02, 2010 | 1995 Lexus LS 400
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
Red light on, car has 164000 miles what maintenance is required
Not knowing what you have done and when below are the normal intervals for Checks and Replacements:
Check Battery Electrolyte Level, Post and Cable Connections
Check Engine Coolant Level + Reservoir
Rotate the Tires.
Check Cooling Hoses & Connections for Leaks & Damage,
Replace Air Filter
Replace Ignition Wires.
Every 60,000 miles:
Feb 15, 2010 | 1995 Honda Accord
Service B for Merceds 2005 c230
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Jan 01, 2009 | 2007 Mercedes-Benz C230 Sedan
Computers & Internet Logo
David Payne
David Payne
