Question about Westinghouse Washing Machines
Why is my westinghouse stove top,elements overheating
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Posted on Apr 02, 2009
How do I wire Westinghouse oven pon 663 to stove top Westinghouse pon663' ive piggybacked stove top to oven but the stove top is not getting as hot as it should
I shouldn't be like this, but what the hell are you doing messing around with something you don't understand and could kill someone!!??
Apr 04, 2016 | Kitchen Ranges
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Replace fuse in an old Westinghouse 229 fan-forced oven.
Not sure, but if you're lucky the stove will have a schematic inside. Take the back off, see if one is glued to the back or in an envelope. If back is 2 pieces try top behind controls first. Unplug 1st!
Mar 14, 2014 | Dryers
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
I have a 1950's westinghouse electric stove and I am looking for parts. Specifically the heating element for the oven?
I have a 1950s westinghouse electric stove for sale with the original owners manual in mint condition... please email me if you are interested... mgsromaniello@yahoo.com
thanks and i look forward to hearing from you
Jul 27, 2010 | Kitchen Ranges
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
The elements on the stove top will go on full or nothing at all. Is there an easy fix for this ?
the elements are supposed to do this, being on or off. however, if they do not turn on and off to maintain selected temperature, means the thermostat in the oven needs to be replaced. on newer fancy ovens it may be the electronic control panel
Nov 03, 2009 | Westinghouse Bethany Antique Brass- Indoor...
How do I replace the bottom element of a White Westinghouse 18-203101 oven?
Hi thanks for the question. disconnect power to the stove. 2 screws on the element . remove . pull element out . replace element. thanks the appliance doc. Please rate my answer. thanks.
Oct 07, 2008 | Kitchen Ranges
Westinghouse Kimberley Electric stove
The temperature control thermostat mechanism in these switches are frail, low quality and repeatedly fail. You will know they have failed (again and again) when you turn the stove ring on and you will only have full temp with no variance.
They must be replaced.
Most places sell the replacements at insane markups, sometimes as much as $50 each! They can be had for almost a quarter of that price. There is no difference between the $50 and $15 controls regardless of what the rip off merchants will try to tell you.
Ideally these controls should be replaced free of charge by the stove manufacturer as they have used a very inferior component in their product during the manufacturing process.
They have been used by several common manufacturers for many years but still have made no effort at all to correct this very dangerous condition.
The danger factor of this fault is ignored but should receive the utmost attention by the autorities asap.
Jul 13, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Washing Machines Logo
43 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
