Question about Koolertron For 2009-2012 Kia Cerato /Forte Koup 5-door DVD Player with GPS navigation and 7 Inch Digital HD touchscreen and Bluetooth
Misfire on number three cylinder - Koolertron For 2009-2012 Kia Cerato /Forte Koup 5-door DVD Player with GPS navigation and 7 Inch Digital HD touchscreen and Bluetooth
    Top Expert:
  • Koolertron Master
  • 42,545 Answers
Check/ rep[lace the injector
check the wiring and connections for that injector
test the injector by relocating it in another cylinder spot to see if the miss moves the same
Posted on Jun 18, 2015
Why is there a cylinder 2 misfire?
Check these three things in the misfiring cylinder: spark, gas, and compression. One of them is wrong or missing. For spark check the spark plug and wire. Make sure you have spark on the plug wire, a strong blue spark. For gas, the fuel/air mixture may be wrong. Does the fuel injector pulse, putting gas into the cylinder? Possibly you may have a leaking injector or a clogged injector.
If gas and spark seem okay, you need to check compression in the cylinder. Low compression will cause a misfire. If compression is 20 or 25% lower than adjacent cylinders, that could be causing a misfire. For example, say numbers 1 and 3 cylinders had about 150 psi compression. 80% of 150 = 120, so if cylinder 2 is 120psi or less, that could be setting the misfire code. Low compression can be caused by valves not seating well, or bad piston rings, bad head gasket- something in the combustion area of the cylinder is losing compression.
Aug 17, 2015 | 2006 Mazda Tribute
Number 3 and 4 are not firing from coil on 2002 subaru outback 2.5
its faulty coil.
Get the compression test done on each coil.these will let you know if its faulty coil or not.
It can be issue with spark plugs or faulty spark plugs. Also get the compression test done for cylinders. If any of cylinder shows low compression then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla: Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Cylinder 1 misfire 2003 chevy impala.. My car started running rough all of a sudden today. like the engine was shaking. took it to auto one said cylinder 1 misfire. what does that mean & what should i...
a number one misfire means that the number one cylinder is no longer working as good as it should or is not working at all. The number one cylinder is on the back side of the engine on the passenger side. 1-3-5 are the three cylinders in the back.
Three basic things can cause a misfire.
1. a bad spark plug wire
2. a bad spark plug.
3. a bad injector.
Remove the sparks plug wire from the spark plug and remove the spark plug. Inspect the inside of the wire and the outside of the plug to see if there is any carbon tracking. it will look like black lightning bolts. If there is any carbon tracking replace the plugs and wires.
Check the spark plug gap. It should be around .060". if its over .080" the plug is worn out.
Check for spark with a spark tester.
the fuel injector is a little trickier.
Start with the things above and let me know what you find and we'll go from there.
Sep 28, 2011 | Cars & Trucks
I have a 2001 dodge ram 1500 4wd and three codes came up P 300 p 301 and p 308 what are these ??? help please!!
The codes mean as follows
PO300 multiple cylinder misfires
PO301 #1 cylinder misfire
PO308 #8 cylinder misfire
Some of the more common causes for these codes popping at once are, if you went through a big
puddle and the engine and wires are wet or the distributor cap and/or wires are bad or the camshaft
sensor(located inside dist cap) is bad and sending false signals. Hope this helps.
Oct 29, 2010 | Dodge Pickup Cars & Trucks
Missing under load, number three cy,inder was
Next step is the camshaft position sensor.
Mar 21, 2010 | 1999 Suzuki Vitara
1998 windstar 3 litre number 3 misfire ,changed plugs, wires, coil, injector, any ideas?the only codes are number three misfire
did you leave your battery hooked up while you were replacing the spark plugs and coil and such? try resetting your ECM.
Jan 15, 2010 | 1999 Ford Taurus
I have a diagnostic trouble codes p1768,po300,and a po420. what does this mean?
I have tow of the three requested codes. po300 is misfire detected at multiple cylinders. See po301-306 represent the cylinder # misfire. So 301 is cylinder #1 misfire.
po420 is Catalytic Converter Efficiency Failure
Oct 08, 2009 | 1996 Plymouth Voyager
Misfiring cylinder
P0303 is a misfire on cylinder 3.
Jun 07, 2009 | 1998 GMC Jimmy
Koolertron For 2009-2012 Kia Cerato /Forte Koup 5-door DVD Player with GPS navigation and 7 Inch Digital HD touchscreen and Bluetooth Logo
Top Koolertron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Koolertron Audio Player and Recorder Expert? Answer questions, earn points and help others
