Question about HP Pavilion dv1000 Notebook
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
  • jesu marasi Jun 23, 2009
    thanks thats very informative !
  • 92 Answers
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
Posted on Jun 23, 2009
To upgrade the CPU HP DV1000 Chipset Intel 855 GM
http://ark.intel.com/chipset.aspx?familyID=24596
Upgrade na:
Pentium M 760 2000 2048 533 is OK
http://ark.intel.com/Product.aspx?id=27595&processor=760&spec-codes=SL7SM,SL869
Hi Standa
Posted on Mar 17, 2010
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
Jun 13, 2011 | Compaq Presario 6450NX (DA238A#ABA-BDL1)...
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Can i upgrade my processor?on my toshiba satellite m55-s135 laptop? I am upgrading the ram from 512mb to 2gb and the hard drive to 200gb.
dont know what processor you have. If you have a celeron M you can probably upgrade to a pentium M without any problem. The ram you should check. I believe that motherboard will only support 1.5 gb. Any more you will be waisting your money.
Sep 26, 2009 | Toshiba Satellite M55-S135 Notebook
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Upgradation
the maximum upgrade for its processor is Pentium III.
go to www.dotstation.info for more details
Feb 04, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
DIAGRAM FOR A LABELLED 512MB RAM
start at: www.crucial.com They have very good tutorial pages for RAM upgrades.
Dec 07, 2007 | Dell 2.8 GHz Second Processor for...
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
HP Pavilion dv1000 Notebook Logo
3,519 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
