Overview of Adobe Premiere and Flip Camcorder:
Adobe Premiere Pro is one professional, real-time,timeline based
video editing software application.
Flip
cameras store their video in a high-definition MP4 format. However,
you will likely not be able to edit the video by importing it into
Premiere Pro without converting it. The best solution to make Flip
Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro
version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter
Flip to Adobe Premiere Converter is a magical app for Premiere Pro
fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
(MPE,MPG), AIFF, MP3, WAV, WMA, etc.
Flip Video to Adobe
Premiere Converter easily convert flip camera videos to
Premiere Pro with no quality loss. Under the help of the Converter, you
can import the output video and edit it in Premiere Pro with ease, no
matter which Adobe Premiere Pro version you possess. Furthermore, it can
also support you to
import
Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several
simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI,
MOV, MPEG etc.
Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add
File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like
DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip
camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats,
you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into
Adobe Premiere Pro?
Adobe Premiere
accepts you to import a single video clip, multiple clips, or an entire
folder of clips. You can also import a variety of audio and still image
files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click
Open.
Tip2: To import multiple files: Hold down the Control key to select
multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you
want to import, then click Folder. A new bin is created in the Project
window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from
"Finder" into the Project panel.
Why not
download Flip Pro to have a try?
