Question about American Standard 4332.001 Pekoe Kitchen Faucet
My pekoe faucet is brand new and leaking at the handle
    Top Expert:
  • American Sta... Master
  • 44,414 Answers
Return and get a new one
Posted on Jan 24, 2015
4 Suggested Answers
  • 6 Answers
SOURCE: leak in the faucet handle
You'll need an allen or hexkey wrench of the apropriate sixe to remove the handle from the faucet. There should be a rubber plug with the traditional red and blue colors for hot and cold. Carefully pry the plug out. There should be a hex nut in behind the plug.Remove the hex nut and the handle should come off by pulling straight upward.After that the dome shaped nut that sits below the handle should turn off counter clockwise. Beneath this is where the seals, springs, and washers are located. Good luck
Posted on May 20, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
packrat1948
  • 528 Answers
SOURCE: base of faucet leaks- cannot remove set screw at
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Posted on Feb 25, 2011
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Tip
    How to repair disc-type faucets
    DISC-TYPE FAUCETS
    • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
    • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
    • Use pliers to pull the disc assembly out of the faucet.
    • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
    • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
    • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
    • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
    • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
    on Jan 16, 2010 | Plumbing
    How do you repair a leaky centerset Kohler forte fauset
    That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
    May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
    Leaky faucet
    Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
    Nov 11, 2012 | Washing Machines
    My delta faucet 172-sswf waterfall single handle kitchen faucet is leaking at the handle or lever how do I repair it?
    i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
    Jul 13, 2012 | Delta Faucet Delta 172-SSWF Waterfall...
    The hose running thru to the faucet head has severe leaking. Can this be repaired?
    yes the hose can be replaced, this is a off brand, if you remember where you got it, you can order a new hose...
    Pleas rate/vote this response thanks
    Dec 19, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
    Water comes out the shower head without the faucet lever being engaged
    the whole faucet is bad it has an internal leak replace the whole thing
    Jul 03, 2009 | Home
    Repair leaky handle
    Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
    Apr 21, 2009 | Plumbing
    Single handle tub/shower leaked, now not working
    you may have installed the stem incorrectly or something is blocking the water passages inside
    Apr 11, 2009 | Plumbing
    American Standard 4332.001 Pekoe Kitchen Faucet Logo
    46 people viewed this question
    Top American Standard Plumbing Experts
    Donni Steen
    john h
    TED
    Level 1 Expert
    Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
