Question about Vtech Lands Phones
We can not set number of rings on answering machine
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you declined to state the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Posted on May 12, 2014
kimehselorio
  • 85 Answers
SOURCE: GE phone answering machine
please provide more information about this problem . thanks :D
Posted on Dec 11, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: How do you set the number of rings before the answering machine picks up?
Here's a link to the manual on AT&T's site:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=284
Posted on Nov 19, 2008
richa33
  • 71 Answers
SOURCE: how to set number of rings
Use Ring Select to choose how many times
the line will ring before the system
answers a call. Set for 2, 4 or Toll Saver.
When you set the system for Toll Saver, it
answers after four rings when you have no
new messages, and after two rings when
you have new messages.
1. Press and hold "set up" for about two
seconds. The system announces the
current ring selection.
2 Press and release "ANNC/SKIP" or "MEMO/REPEAT"
until the system announces your ring
selection.
3 Press and release "Play/Stop" to exit
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: hOW TO CHANGE THE NUMBER OF RINGS BEFORE THE MACHINE ANSWERS?
This is for a 5.8 GHz uniden. Hit "menu/clock" then use volume up and down key to select number of rings and then below "menu/clock" hit "set". That should it.
Posted on Apr 20, 2009
  • 1340 Answers
SOURCE: Setting number of rings before answering machine kicks in
Probably a cordless right?If it is,there should be a function button on the handset.Without pressing to dial out,press or hold down the function button.If there is a directional type button,you may have to press down or keep pressing the function button to cycle through the options.Once you find the ring set,it will probably require the directional button up or down to change the number of rings.Function could also be on the base,but it's usually on the handset.You may have to play around with a couple other buttons if there is no directional button but most seem to have the directional button these days. Good luck!
Posted on Jul 23, 2010
Testimonial: "Thank you once again for your help!!"
1739 digital answering machine setting number of rings before it answers
After setting the number of rings, press PLAY/STOP to save the setting and exit the menu. Full details are on page 2 of the manual.
Jul 31, 2012 | AT&T ATT1739 Digital Answering Machine
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual, http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1717-_E
Dec 09, 2010 | AT&T 1717 Digital Answering Machine
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
I need to set the rings
Rings to Answer:
THIS SETTING ALLOWS YOU TO SELECT THE NUMBER OF RINGS BEFORE THE UNIT ANSWERS A CALL.
1. The unit announces, "Rings to Answer (the current rings to answer setting). To set rings to answer press NEXT. Press SET to continue.
2. To chantge the rings to answer, press and relase the NEXt OR GREETING/PREVIOUS button and the unit announces a number, such as "2,3,4," or "2, toll saver, 5."
3. After choosing a number, press and release the STOP/SET button to store the rings to answer. The unit confirms the setting and enters Message Length menu.
Taken directly from the instruction booklet that came with my GE 29888GE1 instructions.
Hope it works for you ! jp
Mar 02, 2009 | GE 29888GE1 Digital Answering Machine
Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have a GE29869GE2 Answering machine, no instructions anymore. How do I change the number of times the phones rings before receiving the greeting kicks in?
1. Press set button
2. Use next and previous buttons to select number of rings setting and press set.
3. Select the number of rings you want.
4. press set again to save setting.
I hope this helps. Here's the manual:
29869GE2 Digital Answering Machine
Dec 13, 2008 | GE 29869GE2 Digital Answering Machine
How can I change the Rings to Answer setting to one ring?
1.
Press Setup.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
NUMBER OF RINGS TO ANSWER FAX
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
Lands Phones Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
