Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Flash issue I have a flash issue with my three Moultrie D40 cameras. They all worked fine for about a year, then the flash strted to malfunction and right now the flash is present at about 1-3 times out of 200 pictures. It's the same for all cameras. I guess that it's either the flash itself or the "power component" (I don't know the name for this in english) that feeds the flash. Any knowledge or advices about this? Thanks /Stefan, Sweden
  • Ronald Lockhart May 11, 2010
    Known issue; repair not sure yet...you can go to EBAY, and almost all Moultie D-40 cams listed flash does not work...have bought a few for parts useable on I-40 & I-60 cams
  • Moultrie Expert
  • 296 Answers
Stefan,
Ron here.There are many D40s listed on EBAY with same prob. I have bought a few and presently working on a fix...Moultrie won't support any out of warranty...want you to buy new.
Ron
Posted on Feb 20, 2010
Hi Ron just want to no if you do repairs on the Moultrie D50 trail camera
They are close to the D40s inside but the D50 won't fit a D40s "lunchbox"outer case without modifying it. Both are known for flash problems,which usually ends up being bad charge capacitors (3x 250mfd)..
the ones I can't fix,I rob the LCD menu displays,which rarely fail in D40/D50s, and use them in the I40/I60s notorious for bad menu displays...they are interchangeable with minor mods if any.
Oh, you just asked if I worked on them...
Dec 11, 2011 | Moultrie D-50 Digital Camera
Moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Nov 21, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
How slove the problem
Introduction
Specifications Recommendations
The Nikon D60 is an inexpensive 10 MP DSLR that comes with an excellent 18-55mm VR lens for about $650 as of June 2008. It was a announced in January, 2008, and sold for about $750 with lens in February 2008.
The Nikon D60 is a replacement for the almost identical D40x.
Personally I prefer Nikon's least expensive D40 over the D60 or D40x. The D60, D40x and D40 are actually exactly the same cameras, differering only slightly in their internal electronics, but differing greatly in their prices.
The D60 is actually a D40 body with a few more card-clogging pixels, a VR lens and adaptive dynamic range, but a slower maximum shutter speed with flash.
The D60 is less sensitive to light then the D40 (its default ISO is only ISO 100 compared to the D40's default ISO of 200). Its less sensitive to light because the pixels have to be made smaller to cram more of them into the same-sized sensor. Smaller pixels collect fewer photons than larger pixels. Since the D60 is half as light sensitive, the D60 has to use twice as long a shutter speed or a larger aperture, which makes it more likely to make a blurry picture than the D40. OOPS!
Save your money and get the D40 instead. The D40's faster sync speed is invaluable for use with flash outdoors, and the extra light sensitivity in normal use will help make sharper pictures. These three cameras (D40, D40x, D60) otherwise, for most users, are identical. Compare them in person and you'll see. Megapixels don't matter.
(I detail the few fine points which are new in the D60 further below.)
I had my hands on a D60 back in January 2008. The D60 is an excellent camera, but for most of the people who will buy it, it's the same thing as the $300 less expensive D40. I'd suggest getting a D40 and putting the $300 towards more lenses and/or a bouncable flash.
In fact, the faster flash sync speed (the fastest shutter speed with flash) is more than twice as fast in the D40 (1/500 vs. 1/200), and along with the faster base ISO, the D40 is more likely to make sharper photos for most people, for hundreds of dollars less!
The only significant feature in the D60 over the D40x and D40 is adaptive dynamic range. The D60 does not have any of the other next-generation functionality of the D3 and D300.
The D60 is just a D40 with more pixels, but slower shutter speeds with flash outdoors and less basic light sensitivity due to the smaller pixels needed to jam more of them onto the same-sized sensor.
I make excellent 12 x 18" (30 x 50 cm) prints from my 6 MP D40; do you plan to print bigger? Really? The resolution makes no difference unless I'm printing at 20 x 30" (60 x 80 cm) or more.
Since the D60 costs $300 more than the D40, I'd much rather have a D40, 1/500 flash sync for better daylight fill-flash range, a minimum ISO of 200 and $300 left over to buy lenses and an external flash that I can bounce for better lighting. For instance, the D40, 55-200mm VR and SB-400 is a far better way to spend the same $750.
Sep 19, 2011 | Nikon D60 Digital Camera
My D40 camera will not make night pictures consistently. About 90% of the time pictures taken at night are just black. From what I have read on the forums this must be a very common problem.What is the...
D40s are well known for flash failures...in 3-shot burst mode, due to charge time of flash circuit, 1st pic good; next 2 black. Battery life greatly reduced in this mode.
Feb 26, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My moultrie d40 camra the flash stop working
I have the same problem and I am still unable to find out why it stopped flashing or how to fix it. If anyone has any info. on how to fix the flash issue please let us know.
Nov 01, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How to repair Moultrie D-40 camera
The component you are referring to, on bottom of PCB, is ID'd on PCB as D19...The component itself has 3 fine lines on end toward top of camera, and S12 is printed on top. Looks to be black carbon.
Hope this helps..am better than a novice in electronics, but don't have tools to work surface mount devices.
Jan 22, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
The flash on my camera
There is no top LCD on the D40. Put the camera in AUTO mode (green icon on the dial) and take a picture in the shade. if the flash does not go o, then you have a fault. Send back to authorized repair centre.
Dec 09, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash not working
Hey influenza,
Nearly dropping the camera should not affect the operation of the flash unless the flash was extended and you caught the camera by the flash and it is somehow physically damaged. What is more likely is the camera is either set to a mode that doesn't allow the flash to operate, or the flash is set to auto off. Directions on how to turn the flash on or off start on page 34 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.nikonusa.com/pdf/manuals/noprint/D40_noprint.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dgs 200 moultrie flash failled
I have the same problem with my camera. I contacted Moutrie about the problem and I was told that the capacitor for the flash is not charging. I asked for moutrie to send me the capacitor so that I could replace it, but they do not send out parts for cameras. If the camera was bough within the last year, it has a 1 year warranty and moutrie will fix the camera.
Nov 17, 2007 | Moultrie MFH-DGS-200 Digital Camera
Flash not working on Sony CyberShot DSC-P93A digital camera
The flash on my Moultrie gameSpy 4.0 (D40) quit working. I can trigger the camera and see the flash is very week. Batteries are 100%. Can the flash be ordered and replaced?
Nov 11, 2007 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
534 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
