Question about Radio Communications
Schematic gemtronics gtx 3000 cb
Power cord wiring diagram
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Look around on the board there has to be some markings as to where the wires go.Look to where the cord came in and those contact points can't be far from the enterance point.
Posted on Sep 15, 2014
4 Suggested Answers
SOURCE: cb maxcom 30E
can anyone tell me if a maxcom 30e is any good
Posted on Mar 22, 2009
  • 773 Answers
SOURCE: Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Posted on Apr 25, 2009
  • 1768 Answers
SOURCE: How can I get a schematic diagram for my Radio
this site may be of help.
I hope this helps. Have a great day.
http://www.eserviceinfo.com/index.php?what=search2
Posted on Oct 04, 2010
I need a schematic diagram for a cb radio the radio is a electrophone model cb-550 PCB is a PTBM058COX with a SWR meter PCB PTSR007AOX need it to wire the SWR meter to the main board please help?
This circuit board is manufactured by Uniden, I believe. I was searching for it last week and found it by googling PTMN058COX Schematic. There are many brands using this board so don't worry about the brand name. Just download the file.
Oct 11, 2016 | Radio Communications
Echo wires diagram
why waste your money on an echo board .you should buy an echo chamber . They operate on the outside of the radio so people that don't know how to wire one in can still have one.the echo board should have come with schematics,if it didn't you may have to google it to get the schematic you need.
Jan 16, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
Where can I find a wiring diagram or a schematic for this charger
If you can't get the schematic on Google, test between the black wire and the connectors available. One that has continuity with some resistance is a good candidate. One that has no resistance probably is another connector for black....
Nov 24, 2013 | Hardware & Accessories
I need a schematic for a uniden pc 78 elite cb radio
I will assume you have also looked for the schematic as a Cobra 29ltd which is the same radio----Check the internal speaker with a meter first and also examine the external speaker jack which will cut the inside speaker off.
Lastly a microphone with a broken wire in any area will kill receive audio.
Dec 20, 2012 | Uniden PC-78 ELITE Mobile CB Radio
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
The power wire hook up for the trc-481 cb radio
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 18, 2011 | Radio Shack Radio Communications
I have a old tube cb base station gemtronics 5000gtx i found in trash years ago its missing the ac powercord but has the round plug that a powercord would be soldered onto was wondering how you would...
Hi, my name is John. The older tube type radios usually ran (ac) base or (dc) mobile, and would probably need a lot of work done to it to restore it, such as capacitors, they leak and no longer any good. You could be investing a lot of money in it. If you need further, I will be glad to help, I will post it here. Good luck... Hope this was very helpful..rate this solution on the 4 thumbs-up......John
Sep 06, 2010 | Radio Communications
My book shows 3 different configurations on one all but 2 of the pins are hooked up. If you want you could look the hook up info online. Or call the folks at (706) 270 3829 they will send you a email with it in it for free.
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
Sep 15, 2009 | Cobra 29 LTD CB Radio
Radio Communications Logo
127 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
