Question about MSI P4MAM-L (MS-6787) 400/533 MHZ FSB Socket 478 All-In-One Motherboard OEM (MBSK478P4MAML)
What is the specification of the memory? - MSI P4MAM-L (MS-6787) 400/533 MHZ FSB Socket 478 All-In-One Motherboard OEM (MBSK478P4MAML)
  • MSI Master
  • 10,045 Answers
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
Apr 26, 2014 | Acer Aspire Z Series All-in-one Touch PC...
My dell optiplex gx530 doesn't start when memories are inserted
The beep (Posting) will sound off ONCE if the board is working properly. If you get several beeps, there is a mismatch.
Memory has a specific Voltage application. If that specification is incorrect, you could BURN out the new memory. Just any old memory stick that fits the slot will not function. It must be compatible 100%. Read the data on the original memory; example DDR2 or DDR3...speed 1600 MHz etc. Voltage 1.8, etc. Match up the correct memory sticks and your good to go.
Dec 21, 2013 | Computers & Internet
What specific memory card is required?
Memory cards should be formatted before use. They should also be formatted each time you finish downloading pictures from it.
Jul 05, 2010 | Vivitar ViviCam 3720 Digital Camera
What are the memory specifications for the Foxconn 661MO3C-6L?
The memory specifications are as follows...
System Memory
Two 184-pin DIMM slots
Supports PC 3200/PC 2700/PC 2100 memory
Supports 128/256/512 Mb technology up to 2GB
Mar 17, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Gateway wont take new ram???
Was the memory made for that specific model? I know that on Toshiba laptops sometimes you have to buy the memory that was specifically designed for that model. You can always try a website like kingston. They may make the memory specific to your laptop mode. If you would like more help please feel free to reply.
Mar 20, 2009 | Gateway MX3225 Notebook
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Ram compatibility
pc2100 works on 266Mhz
pc2700 - 333Mhz won't work. If u have a pc 2100 supporting computer u can put a pc 2700 memory(it will work on the lower speed)
But u can try anyway... nothing can get damaged ... (i think, at u;re own risk...)
Jun 29, 2008 | Computers & Internet
System upgrading
I think your memory specs is DDR 400 nonECC.
Maximum-is 2GIG
please refer to this site for more info.
may this help, melnavz
Mar 17, 2008 | Mercury P4VM800M7 Motherboard
MSI P4MAM-L (MS-6787) 400/533 MHZ FSB Socket 478 All-In-One Motherboard OEM (MBSK478P4MAML) Logo
75 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
