Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
Craftsman mandrel replacement::?????HELP
I have to replace a new complete mandrel on a 42" craftsman...my ? is do i have to drop the deck to replace this ..What is the ez way to do this..Thank you joe...
  • Anonymous Mar 22, 2014
    Cfaftsman mandrels wear out
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Posted on Jun 23, 2009
    Scholar:
  • 81 Answers
Easiest way to replace mandrel on any mower is to remove the deck from the mower. This gives you better access to the problem. Normally they are not hard to replace.
Right mandrel assembly for craftsman model 917.273020 does the stripper, mower round attach on top of or under housing of mandrel?
The part called the stripper goes between the mandrel housing and the mower deck.
Hope this helps, if so please vote yes! Thanks!!
May 27, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
How do I change the madrel on a craftsman Lt 2000 42" 17 hp? The star bolt is worn down
remove the deck from the mower, take off the blade, take off the deck drive belt, take out the bolts which hold the mandrel to the deck. put new mandrel in, reverse the whole order. do yourself a favor and take lots of before pictures so you do not have to ask how to put the belts back on. mandrels can be obtained at small engine and mower repair shops. you may just want to replace all of them while you have it apart as they are all the same age and wear.
Mar 17, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i take out the mandrile
remove the blade, remove the deck from the tractor, remove pulley covers, remove the deck belt, remove the bolts holding mandrel to deck, remove the mandrel. reinstall in reverse order.
Jun 23, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When I replaced Blades Theirs a star shaped shaft that the blades slide on before you place bolt on. I noticed the star shaped shaft is rounded off. How do I repair this? THANKS!
I think you must replace the entire mandrel. Small engine repair shops carry them, expect about $40.00. Drop the deck, take off the blade drive belt, remove 3 bolts, your blade is already off, take mandrel out and install new one in reverse order.
Jun 14, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Cutting blade barring ***
I think that part is called a mandrel, pulley on top and blade on the bottom.
Generally you remove the deck, take off the deck belt, take off the covers, take off the blade, remove the bolts holding the mandrel to the deck. Get a new mandrel at a sears store or small engine repair shop and reassemble in reverse order. May want to do them all while you are at it and save yourself duplication of work next year.
Jun 04, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
How to replace the right side mandrel assembly on mower deck
you will need to jack up the mower drop the deack dowen remove the belt then the pulley remove the bolts that holds it on you may want to remove the blad first take it out befor you put the new on in start the bolts in the holes of the new onethat way its not so hard to get started if you brake a bolt its ok it happens to me all the tim you will just need to get some new ones i allways get new ones when i get a new housing hope this helps ya
Oct 01, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mandrel chews pulley
Are you sure the spindle is not bent and also are you balancing the blades when sharpening. Other then that make sure bolts are tight on the mandrel. With the deck off and standing up spin the blades and watch center of balde to see if something is bent. Also watch pulley on the other side to see if its bent.
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
1,584 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
