Question about Whirlpool Microwave Ovens
Why wont whirlpool wmh32l19as start button work?
What do i do with my whirlpool mhe14xmg-2 microwave, the time displays ,but it wont start.
Start by checking all the door switches for proper operation. If all ok, then check all thermal protectors and check all wiring connections.
Oct 06, 2016 | Whirlpool Microwave Ovens
I have a Whirlpool microwave oven model number m T 7 118 xD Q all the other buttons work but when you push the start button it does not work can you tell me what the problem is?
There is a fuse inside your microwave that might have blown. Take cover off unit unplugged make sure unit is grounded. Remove blown fuse. This should fix problem. Also check that the door is closing all the way. Put pressure on door and see if it starts.
Feb 01, 2015 | Whirlpool Microwave Ovens
Whirlpool microwave start button not working
There are 2 possibilities the first is that the button is locked. Some modern microwaves have lock buttons so children do not play with them. To unlock it you can try either holding th "start" button until you hear a tone of hold the "stop/end" button until you hear a tone. If that does not work it means that the button it self underneath of the plastic is broken or blown which means that it must either be repaired or the microwave must be replaced. For the price it may be more cost effective to replace it is the button is broken.
Sep 26, 2012 | Whirlpool RMC305PD Microwave Oven
MY MICROWAVE WONT START BUTTONS WORK BUT WONT
the problem with microwaves is there like light bulds,,, fine for years then the just pop off, whatever it is there is very little you yourself can do with it bar check the plug fuse,, if thats ok dont even think of opening it up to have a look inside, you are very likley to just kill yourself
inside that microwave is a big capacitor that holds 1000, of volts and they can and do kill if you tuch the wrong bits of them,
have you ever seen a stun gun work? well that capacitor is its very big brother, only it wont just stun, it will kill you out right...is it worth the risk??? no! so drop it in the shop for repair or better still bump it and get a new one,, and up grade it as well,
Oct 24, 2009 | Whirlpool MH7135XE Microwave Oven
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave wont start
go to repair clinic .com or similar site.Will need make model # serial#
Jan 07, 2009 | Microwave Ovens
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
