Question about Stanley Garden
What year was the Stanley Model 223230X692A lawn mower made
MNfisherman
  • 11896 Answers
SOURCE: lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Posted on Jul 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a 2 year old push mtd lawn mower , it wont ...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
SOURCE: scott bonnar lawn mower service manual model 520...
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
Posted on Sep 21, 2010
SOURCE: Can a serial number tell me what year a lawn mower is?
I think so try looking it up more there may be a place to type it in and it will give you info about it.
Posted on Feb 27, 2012
jlgprop
  • 352 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
FOR SURE CHECK ALL PREVIOUSLY MENTIONED ITEMS , TRY THIS...ALMOST GUARANTEE IT WILL RUN............ REMOVE "ALL" OLD FUEL, REFILL WITH FRESH HIGHEST OCTANE FUEL. REPLACE SPARK PLUG (YES, EVEN IF IT LOOKS OK!) GAIN ACCESS TO CARB OPENING, REMOVE AIR FILTER..OR WHATEVER. USING SPRAY CARB CLEANER, FILL ENTIRE CARB AND FLOATBOWL WITH CLEANER....WAIT OVERNIGHT IF POSSIBLE..IT WILL EVAPORATE. NEXT DAY SHOOT MORE INTO CARB..GETTING ANY JETS, ORIFICES ETC..FILL FLOAT BOWL AGAIN. P.S. CLEAN OR REPLACE AIR FILTER IF NEEDED! WAIT A WHILE, GAP NEW SPARK PLUG, INTRODUCE APPROX. 1-2 OZ. OF FRESH GAS INTO PLUG HOLE...QUICKLY RE-INSTALL SPARK PLUG ..WITH ON/OFF SWITCH-BAR OFF..PULL OR CRANK ENGINE A FEW TIMES. MAKE SURE IGNITION CAN FIRE, CRANK(ELECT. START) OR PULL STARTER ROPE & MOWER SHOULD FIRE OVER. IF IT STARTS..RUNS..THEN STALLS (AFTER USING UP GAS IN CARB, TRY IT AGAIN. IF IT CONTINUES TO STALL QUICKLY...YOU WILL NEED AT LEAST A CARBURATOR REBUILD, OR IF NO START AT ALL..YOU NEED TO SEE IF PLUG IS FIRING.
Posted on Apr 05, 2014
Changing blades on 52 in Stanley lawn mower model # 525602x692b
You may have to get a block of wood or sometimes I use vice grips to hold the blade from turning and put a short steel pipe and put over the handle of my extension bar with socket on it. Also I have used WD40 and once I heated the bolt area with a torch to make it expand. I have done these and finally got them off. Oil them before you reinstall.
Jun 25, 2016 | Garden
Cub cadet lawn mower won't start and i have changed everything
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Where do i find parts for my stanley mower?
Stanley Mowers were made by Murray. Most Lawn mower repair / parts stores have replacement parts for these mowers.
Even if you do not have a model number you can probably use this link (left side of page) to find your part.
http://www.outdoordistributors.com/Murray/Murray_Pushmower/Murray_Pushmower.html
If it is just an engine part that you need mose of these had Briggs and Stratton engines onthem and the engine model number and type code are on the air shroud just above the spark plug for engines 4 HP or less.
Jun 13, 2010 | Garden
Mower will not stay on
See if a belt has slipped off. Sometimes they will come off and jam up in the pulley. When you let off the brake you are actually engaging the pulley, if it's jammed up it will cause the engine to bog down and quit.
Apr 20, 2010 | Garden
HAVE LAWN BOY MODEL S19ZPNA, WHAT YEAR OR YEARS
1990 was the only year it was made.
Good Day.
Oct 09, 2009 | Garden
What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Sep 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
19 HP stanley riding mower, wiring diagram
i have a stanley lawnmower 19hp 2003 year where can i purches parts for it need carbs for it.cannot seem to find inything on line.
Jun 12, 2009 | Garden
Garden Logo
29 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
