Error codes fisher paykel
What does F5 mean on model BI602 oven
SOURCE: Fisher and Paykel Intuitive has
I had the same problem, code 43 is an out of balance switch problem, i found mine was just sticky, if you pull it out (under the electronic control unit, under the top panel) you may be able to find out if its stuck or if it needs a new one, you could possibly find one from another model. hope this helps
Posted on Dec 26, 2008
Karthik316
  • 187 Answers
SOURCE: Where can i download the manual for a fisher & paykel excellence
Hi   try this link
http://safemanuals.com/user-guide-instructions-owner-manual/FISHER%20%2526%20PAYKEL/GW712-_E
please rate my suggestion..
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
  • 713 Answers
SOURCE: how do I take apart my fisher & paykel top
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
Posted on Oct 08, 2010
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Dishwasher
please clarify the model number and also whether you are getting F5 or E5 error code.
Feb 11, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel double dish draw has stopped working and is coming up with F5
Hi.
F5 is Lid Fault.
Try clearing the error code by disconnecting power from circuit breaker for five minutes. If that does not help, then there is a problem with lid switch. The part must be tested and replaced.
Regards.
Ginko
Aug 20, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Error code f5, and inconsistent heating in top oven.
You need to replace the temperature sensor in the top oven cavity. I can't get you a part number or price because I can't find any service info without exact model number. Contact your local appliance parts store. It is easily replaceable with just a coupla' hand tools.
Dec 04, 2010 | Fisher and Paykel AeroTech Double OD302...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
How do i fix an F5 error code on a Fisher & Paykel Dishdraw DS605. I have turned the power off but the error keeps returning?
I am assuming you have the DD605 double drawer dishwasher. Is the problem F5 on both drawers or just one?
F5 code involves the drawer lid seal and will need a bit of effort to check and fix.
Take the drawer out and inspect the inside of the top panel for a black rubber strip. If it is broken or not responding to up down movement then it needs to be replaced. In addition the actuator motors on each side that drive the seal could be faulty.
If you are not comfortable with repairing slightly complex apliances then you may have to call the technician.
Jun 17, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My f&p wall oven model number BI602 is not reaching temperature
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer.
Mar 09, 2010 | Fisher and Paykel Ovens
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Aug 24, 2008 | Refrigerators
Error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Jul 05, 2008 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
