How to replace the hdd - Computers & Internet
    President:
  • 1,185 Answers
Remove the power supply
Remove the battery
Then
You look at the base of your laptop and remove the screws of the panels which look like inspection plates
Underneath one of them you will find a hard drive unit
Some are held in place with a retaining screw
Remove that and look for a tab which allows you to pull the drive backwards (It is plugged into the motherboard by an edge connector)
You may have to rock the drive slightly to get it loose.
Make sure you have a bootable copy of the software and the drivers before you dismount the old drive?? .
Posted on Jun 23, 2009
    Sergeant:
  • 173 Answers
Give em your harddik company like SAMSUNG OR SAEGATE?
How to replace hdd on Sony RDR-HXD860 DVD Recorder/HDD Recorder?
The HDD must order from Sony It can not replace with the computer HDD.
May 04, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
F105 failed error
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover t he data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
U need to update firmware if replace HDD
Sep 16, 2013 | Toshiba E-studio 281c Copier
Copier reads e7-03
E7
Content HDD trouble
Detail
HDD connection failure
If the HDD responds an error or does
not respond for 30sec, it is judged as
an error. (Other than the system area)
Data abnormality in the file
management area (when the cluster
chain is broken)
Cause
HDD is not installed properly to the ICU
PWB.
HDD does not operate properly in the
ICU PWB.
ICU PWB trouble
Check and
remedy
Check installation of HDD to the ICU
PWB.
Check connection of the harness of
HDD to the ICU PWB.
Use SIM 62-2, -3 to check read/write of
HDD.
Replace HDD.
Replace ICU PWB.
Aug 05, 2011 | Sharp MX-2300N Color Copier
After diagnostic, I have discovered that my Xbox 360 hdd is faulty. I need to replace it with new hdd. I would like to know how to load xbox os on hdd etc.
the xbox's OS is on internal flash memory, not the HDD. just replace your HDD with a new one, and it will all work fine.
Jun 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Replaced dad hdd on 5 yr old Acer Laptop 290, unable to load xp
The bootable cd or restore cd looks for a specific folder on the HDD and or HDD serial number and since BOTH have changed due to the replacement of the HDD you will not be able to use the restore cd. I would Contac Acer by phone or check the web site to see about a work around.
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
HDD is cactus, what are replacement alternatives for the OEM?
You can use any 2.5 inch ATA/IDE drive as a replacement. Notebook hdd's are a smaller size than regular desktop hdd's. You can find a good idea online at stores like tigerdirect.com or newegg.com. Hope this helps & please rate this answer fixya. Thanks.
Feb 03, 2009 | Hitachi hts548080m9at00 80 GB Hard Drive
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
Hard drive not recognized
If the HDD is not being detected in BIOS...
--- Then first thing u have to do is to reseat the HDD cables both data and sata cables....
-- If still not displayed in HDD---needs to replace the HDD.
--- If displayed----Then enter into BIOS----select ur HDD from the list---select smart support and then run the samrt short extended test.
If test fails then needs to replace HDD.
Thank You...
Nov 07, 2008 | HP Computers & Internet
Replacing the HDD
hellow
before you replace your hdd ,,
step1. format the new hdd on the pc FAT system
step 2 . set the player 2 default set then replace the hdd..
reply this post when not work
Apr 20, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Computers & Internet Logo
187 people viewed this question
Alun Cox
David Payne
David Payne
