Question about Kenmore Dishwashers
Kenmore dishwasher Model# 13293 door does not line up
Unit level - door offset to the right and the door is higher then the tube and will not close
gisvc
  • 40 Answers
SOURCE: decible level for a Kenmore model 16625691 ultra dishwasher
HI,
ACCORDING TO SEARS TECH SERVICE THE AVERAGE DECIBLE READING IS 53.5 DECIBELS
HOPE THIS HELPS. THIS IS ONE OF THE QUIETEST MODELS IN THE CLASS OFFERED BY SEARS.
Posted on Mar 30, 2009
SolutionGuy
  • 331 Answers
SOURCE: Latch on my Kenmore dishwasher model# 363.14582100 won't close
Sharon,
The "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
This may take several attempts to get it just right, because you want the door closing tight enough so as not to allow a water leak and loose enough for you to close it easily.
If you have any questions, post back and I'll try to explain in better detail.
SG
Posted on Apr 01, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore dishwasher model # 665.15522000 leaking badly
Hi, Make sure the jets in the spray arm ore not plugged at all. Check the black bellows on top the lower spray arm and see if it has a split in it. Let me know if these help or if I can assist you further.
Vic
Posted on May 21, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore dishwasher leaking from bottom of door
This is commonly caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $115.
2. Replace the door seal at a cost of about $35-$40.
Parts can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite dishwasher model 665.17054402 will
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Mar 09, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
I have no way to connect to the granite counter top. Can it be mounted to the side cabinets?
Need prefix for model number. Need complete model number. I believe that the numbers that you have given are stock numbers from your user manual. Kenmore can be several different manufacturers. Some brands have kits to mount unit from the sides using brackets at the top. If stainless steel tub, look for removable plastic caps on the right and left sides of unit. These holes would be used for installing bolts into cabinet. If plastic tub and no kits are available holes can be drilled into sides to secure unit to cabinet. As long as heads of bolts(screws) are flush to allow door closing, unit will not leak because of tub(door gasket.
Feb 15, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Brand new kenmore dishwasher leaking out the front
Check the door gasket for uniform seating. Align it. If this does not solve the problem, contact the service provider. He may change the gasket or do the corrective action.
May 25, 2010 | Kenmore 13743 Staimless Steel Built-in...
Where can I find the model number of my kenmore dishwasher
There should be a label located on the inner lip of the dishwasher where the door makes contact when closed. The label should have the model and serial number. If the label is missing you might find one on the unit if you pull it from the cabinet.
Nov 18, 2009 | Kenmore Dishwashers
Right hand door spring appears to be shot -
It sounds like the spring is dislocated. May just need putting bck in the right place.
May 02, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Erestanding Equator PLS600 Overflows
May be this time the drain hose has been clogged or the drain hose is at a higher level than the unit or may be the drain pump has stopped functioning.
Mar 09, 2009 | Equator 20 in. PLS600 Free-Standing...
Door won't latchet
Start my using a bubble level to make sure the unit is squarely mounted. Even small amounts of offset or tilt in the unit can eventually cause the latching mechanism to fail to work properly.
Jan 27, 2008 | LG LDF6810ST Stainless Steel Built-in...
Its a kenmore 665.17032403
665.17032 403
Plastic over one of the control buttons has started to peal off control panel. Is there is replacment cover or replace the entire control unit?
Aug 21, 2007 | Kenmore 17024 Built-in Dishwasher
Dishwashers Logo
16 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
