Question about Casio FX-115ES Scientific Calculator
How to get memory recall for fx 991ms - Casio FX-115ES Scientific Calculator
  • Casio Master
  • 7,993 Answers
Press the RCL button followed by the letter where you stored some value.
Posted on Aug 27, 2014
5 Suggested Answers
SOURCE: how to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be  calculated with either ln or log function as follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Posted on Apr 24, 2009
  • 7993 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
  • 37 Answers
SOURCE: how to remove memory sign
Overwrite the M memory with zero, by using 0 STO M
ie store 0 into memory M by pressing AC 0 SHIFT RCL M+ (as per keys actually pressed)
Posted on Jun 30, 2011
  • 7993 Answers
SOURCE: to chang fx-991ms to fx-82ms calculator
I am afraid but your question does not make sense to me. These are are two different calculators. What do you mean by change? Is it the same as in fairy tales where a prince is changed into a frog?
Posted on Apr 13, 2012
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How can i store formular in my fx-991ms calculator?
You cannot store any formulas. The device has only read only memory. You cannot add to this memory.
Sep 11, 2015 | Office Equipment & Supplies
Casio fx 991ms
On a fx-991MS? With many other models, including the fx-991ES, I'd say you have the calculator in binary mode but the 991MS doesn't have such a mode.
Aug 03, 2013 | Office Equipment & Supplies
How to remove memory sign on fx-991MS
Jun 27, 2011 | Casio FX991MS Scientific Calculator
How to calculate 0.3log(base 2)0.3 using fx-991ms calc
Your calculator knows only the decimal logarithms log or log_10 and the natural logarithms (ln or log in base e).
So you cannot compute directly the logarithms in any bases other than 10 and e.
A workaround consists in using the relation
log in base b of a number a (log_b (a))
log_b(a)= (log_10(a) ) / (log_10 (b))
or the relation
log_b(a)= ln(a)/ln(b)
log_2(0.3)=log(0.3)/log(2) where log is log in base 10
Similarly
log_2(0.3)=ln(0.3)/ln(2)
As to the multiplicative factor you had at the beginning of your expression, just multiply the value obtained by one on the formulas above (both formulas will give the same result) by 0.3
Jul 18, 2010 | Casio FX-115ES Scientific Calculator
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
M mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
Casio FX-115ES Scientific Calculator Logo
175 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
