Question about LG Televison & Video
VCR dead Only the ''standby'' light/button is illuminated, and I cannot get the VCR to operate. The display remains completely blank. I have switched the mains power of and on, and I have tried to insert a cassette, which I cannot retrieve from the machine. Although completely non-functional, the VCR does seem to have some influence on the TV - a regular flash can be seen on the TV screen at a rate of approx one per second.
  • dutoil Jun 23, 2009
    The posting by ladywinn was helpful in the sense that it gave me an idea what was wrong with the VCR, but it didn't solve my problem, i.e. trying to get the VCR to operate again.
  • LG Master
  • 5,138 Answers
Go to local Thif stores or Pawn shops you can buy a working VCR for$ 5.00-$20.00 ,you have a power supply problem.
Posted on Jun 23, 2009
2005 Jeep Grand Cherokee guages reset
You can try doing a re-calibration of the cluster. To do that.....
Begin the test with the ignition switch in the OFF position. 2. Depress the odometer/trip odometer switch button. 3. While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the ON position, but do not start the engine. 4. Release the odometer/trip odometer switch button. 5. The instrument cluster will simultaneously begin to illuminate all of the operational segments in the VFD units, and perform a bulb check of each operational LED indicator. The VFD segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back. If a VFD segment or an LED indicator fails to illuminate, or if a gauge needle fails to sweep through the calibration points and back during this test, the instrument cluster must be replaced. 6. The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test.
Feb 27, 2017 | 2005 Jeep Grand Cherokee
I need a code for my universal remote so it can connect with my magnavox dp100mw8
Instructions Things You'll Need:
  • Universal Remote Control
  1. Turn on the component you want to program.
  2. Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  3. Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  4. Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  5. Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  6. Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  7. Press and release the STOP button to save the new code.
Feb 02, 2011 | Televison & Video
Need to know how to connect a universal remote
Hello
1. First Turn on the component you want to program.
5 .Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until .the component turns off.
BEST OF LUCK
Dec 13, 2010 | Apex Digital AD-500 DVD Player
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Display black out / problems
Hi, I am having the same problem. and now my screen is completly blank, did u find any other solutions?
Jun 26, 2009 | HTC S710 Smartphone
Beko WMA765s washing m/c 'dead'
Hi press and hold the start button for about 5 seconds .see if this works if not you will have a faulty pcb which will need to be replaced hope this helps
regards dan
Mar 19, 2009 | Washing Machines
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
RCA DVD/VCR model DRC8320
Interface error
(and or)
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
Televison & Video Logo
141 people viewed this question
