Question about Polaroid FLM-3701 Television
Diagram where fuse is in the polaroid flm-3701
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
There is a fuse on the power supply board. It is labelled F1. It is a small cylinder near the AC connector. The F1 fuse is 5A 250V. How ever, capacitors are more likely to fail on this television.
The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light. Any capacitor that is swollen is bad.
diagram where fuse is in the polaroid flm-3701 - diagram-fuse-in-polaroid-flm-3701-1onojclnad5aenzciu2mb45v-1-0.jpg
Posted on Sep 28, 2015
4 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: How do you connect the
You can't connect a coaxial cable to the FLM-3701 because it's an LCD monitor - it's not a TV. The difference between a monitor and a TV is a TV has a tuner. A monitor does not.
This means you can only use this monitor for watching TV if it's connected to an external tuner with AV cables, e.g. a composite cable with red white and yellow plugs. You cannot connect this monitor directly to an antenna or a cable line as it does not have the hardware for tuning/scanning the TV channels.
Cable boxes, satellite receivers and digital converters are all classed as external tuners. You will need to connect your coaxial cable to one of these boxes and then connect the box to the TV with a suitable type of AV cable, e.g. composite, component or DVI.
Hope this helps. If you need further assistance or explanation of anything I've written above, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 16, 2011
caroldon
  • 17129 Answers
SOURCE: model FLM-3701 will not power up.
Yes , there are fuses in the power section but the possible chance is the power supply and Unless the unit is removed to check you will not be able to get a first hand view.Use a multimeter to check and confirm if there is any shorted drivers or capacitors in the SMPS section.Please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Dec 07, 2011
SD Tech
  • 14553 Answers
SOURCE: Polaroid FLM-3701
few and far between as some of these sets were never meant to be fixed----Try three things: 1 is Ebay has literallly thousands of boards for sale used. 2. Google the model number with "parts". Look at places like ShopJimmy.com which number 2 may lead you to.
Good hunting---Google with key words.
Posted on Jun 12, 2012
Polaroid LCD
It looks like your power supply might not be providing enough current to get the LCD to power up. This LCD needs about 3 to 4 amps to work properly.
Apr 12, 2008 | Polaroid FLM-3701 Television
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
Is there a coaxial input on this tv?
No because it is a monitor only; meaning it does not have a TV tuner of its own.
Sep 23, 2012 | Polaroid FLM-3701 Television
Polaroid FLM-3701
Jun 12, 2012 | Polaroid FLM-3232 Television
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Polaroid flm-3701. Power supply is putting out 5 volts in standby. No turn on sig from main board. Bad main?
Look on power supply board for Bad capacitor 2200uf 25v or 1000uf 16v if it is puffed up on top it is Bad, also Main Board is the tuner board
Encompass Parts has some parts in stock for this TV and Free service Manual you can download online 1-800-638-3328 and for capaciotrs Call Mats 1-800-628-1118
Dec 04, 2009 | Polaroid FLM-3701 Television
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
