Question about NEC PABX SL1000
How to make a two trunk access code? - NEC PABX SL1000
How to charge my battery coblt 2007 ,my trunk is locked
You cannot charge the battery (or change it) when it is in the trunk compartment if you cannot access the trunk..
2. With trunk fitted batteries, as used by GM in the Chevy Cobolt, you need to remove them from the car to safely charge them in any event.
3. You will have to get the trunk unlocked one way or another even if that means unbolting the rear seat to crawl into the trunk compartment and try to release the trunk lock manually. You will not be able to access the battery by crawling into the trunk because the trunk floor panel has to be removed to allow access to the battery which sits under the floor panel near the spare wheel.
Dec 27, 2015 | Cars & Trucks
Why my trunk want open
What is year--make--model? Does the trunk have a key lock? Will the key work?
If the trunk release is electric, need vehicle info to look up wiring. Some makes and models, the rear seat back will lower. Maybe you can access trunk, that way, or remove the rear seat-back then see if you can access the trunk?
Aug 08, 2015 | Cars & Trucks
Cables are not hook up to battery someone close trunk now cant get trunk open
Why are your battery cables off? Does the trunk have a key lock? With some makes and models, the rear seat back will fold down, allowing access to the trunk. If not, you may be able to remove rear seat back then see if you can access the trunk.
If the trunk release is electric, have to check wiring circuit and applicable fuse.
What is model year, I'll try to look up trunk release wiring circuit.
May 26, 2015 | Ford Thunderbird Cars & Trucks
How do you access the rear strut assembly on a 2004 Sebring Convertible? The videos show a trunk access but its not there?Is it located behind the back seat?
its in the trunk area over the wheel. you have to remove the trunk liner panel and then you can access the strut mounting bolts
Feb 17, 2015 | 2004 Chrysler Sebring Convertible
1993 honda del sol trunk wont open with key
You might be able to release the back seats and lay them down to climb into the trunk, or the seats may need to be unbolted for access to the trunk.
Jan 22, 2014 | Cars & Trucks
Need the access door code for a 1999 lincoln cartier vin number 1LNHM83W5XY689577
Open the trunk and look on the trunk's support arm on the right side. Should be the code printed on a sticker.
Apr 19, 2012 | 1999 Lincoln Town Car
Cant open trunk, is there access to trunk space from rear passenger seat?
Yes there is access to the trunk from the rear seat but the bad news is the release for the seats is in the trunk on the top passenger side of the trunk.
Jul 01, 2011 | 2005 Chevrolet Malibu
The pad is long with five buttons, two numbers on each button. 1-0
No idea what your question is, but if you are asking what the pad on the door is, it is a code pad to unlock the doors, open the trunk etc. I don't know if they still do it, but Lincoln use to put the base code on the trunk. Look around for a tag stuck to the trunk arm, or trunk lid. When you enter the code it unlocks the doors and if you push other #'s after the code it will open the trunk, turn on lights etc.
Hope this helps.
Aug 28, 2009 | 2004 Lincoln LS
Can we able to trunk one vlan to another vlan
interface GigabitEthernet0/1
switchport access vlan X
interface GigabitEthernet0/2
switchport access vlan Y
interface GigabitEthernet0/3
description trunk port
switchport mode trunk
switchport trunk allowed vlan X,Y
Aug 19, 2008 | Trendware 8PORT SMART POE SWITCH SNMP VLAN...
Colour code for Dark Green Golf 1.4 1997
you can find colour code in trunk of car.pull up carpet look for a white sticker with all the vehicles codes on it .spear tire whel or on round plate to access sending unit.all in the trunk under carpet
Jun 03, 2008 | 1997 Volkswagen Golf
NEC PABX SL1000 Logo
32 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
