Question about Casio Music
N40a35b5 a30c5 a3c7 c7
Where can I purchase a new circuit board. the midi input on my board was crushed when keyboard fell over
2 Suggested Answers
Bennytechkid
  • 99 Answers
SOURCE: "wk-3700" is wrong. Where can I buy parts to it?
If your located in the USA here is casio's USA service and Spares Department:
Casio Parts Department 1-800-223-2001
Parts Distributors
This list is subject to change without notice.
Official Parts Distributors Listing.
California
Pacific Coast Parts Dist. Inc.
15024 Staff Court., Gardena, CA 90248
Tel: 310-515-0207, 800-421-5080
Fax: 800-782-5747
mark_link_def.gifwww.pacparts.com
mark_link_def.giforders@pacparts.com
New York
American Perfit Crystal
520 8th Ave., New York, NY 10018
Tel: 212-246-8292 (NY), 800-345-0537 (Outside NYC)
Fax: 212-265-4085
mark_link_def.gifwww.americanperfit.com
mark_link_def.gifinfo@americanperfit.com
If your in another country head to:
www.casio.com
and you can locate your region and click on support/spares tab at top of page and it will give you a list of contacts in your region.
thanks,ben
Posted on Jan 04, 2011
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix loose USB on M-Audio Keyboard
Uscrew the case, desolder the USB socket from the circuit board. Buy a identical spare from any electronic shop using the broken one as sample. Solder in new USB socket.
USB sockets has only 4 connections - easy job.
Jul 30, 2014 | M-Audio Axiom 49 MIDI controller keyboard
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
May 29, 2011 | Casio Ctk491 Midi Keyboard
Parts Distributors
California
Fax: 800-782-5747
New York
Fax: 212-265-4085
www.casio.com
thanks,ben
Jan 04, 2011 | Casio Music
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Try to get the keyboard to play through out my speackers
Since this has no audio output it will depend upon your computer to generate the sound using the audio system in the computer. You will need the driver software for the M-Audio to talk to the sound hardware in your computer and configure that to accept the MIDI inout from the M-Audio.
You will need to OPEN the volume and mixer controls for your sound board, unmute it, and enable the SYNTH channel and select "general MIDI".
As a test, download VanBascoe's Karaoke thing and play MIDI files to make sure your synth software is working. Then assign the MIDI source to teh USB input from the M-Audio.
Nov 01, 2010 | M-Audio Oxygen 49 USB Midi Controller
Got smoke from inside keyboard and diskette, hard drive and scsi no longer show as available on system screen. Am using midis from HD but can't view it when using disk utilities. I suspect a board is gone,...
Any electronic device that has smoke coming from it is not a good sign. Whether it can be repaired is debateable (it depends if parts are available and costs). Usually in cases such as this it needs a new circuit board and possible other associated components/devices. I suggest the best solution is to purchase a new Yamaha keyboard as a new model would have new and better features.
Nov 19, 2009 | Yamaha Portable Keyboard
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
I have a Casio PX-310 on the service bench . I
As you probably know the regulator also supplies power to the other ICs on the board. If the fuse keeps blowing that means that one of the parts drawing power is shorted. By looking the pin configuration up for each IC you can find which one is the + and which one is the- etc. The faulty IC will be showing voltages on the other pins where they shouldn't be. That is usually the defective part. You will also want to check parts that are related to or in the same circuit. The worse case scenario is that the main IC is shorted. Without the schematic its a long arduous troubleshooting procedure but it can be done and I just thought I would suggest it. I mean know pffence and just wanted to help somewhat.
Jul 09, 2009 | Music
Music Logo
482 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
