Question about Sony KDS-60A3000 60" HDTV
Tv wont stay on
Blinks 9 times how can i fix it
3 Suggested Answers
  • 3 Answers
SOURCE: how do i fix my sony kp-46wt520 projection tv
Called sony and they said send it so we can help fix it.
Mine was a bad "g board"
Sent it to PA (penssylvania)
And they fixed it for & $88 you have to ship G-Board to them and they will return after they fix it if not repairable they will tell you.
(No charge until they fix it.. )
Mine works now and ready for superbowl....YEAH ! ! ! !
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Posted on Jan 30, 2009
hawk127311
  • 350 Answers
SOURCE: the tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Posted on Nov 11, 2009
Need code for my oneforall URC-7140 for my Echostar HDS-600RS
If none of these work 0853 0396 0713 1323 1409 1413 try this,
The Search Method allows you to find the code for your device by scanning through all the
codes contained in the memory of the ONE FOR ALL. The Search Method may also work if
your brand is not listed at all.
Example: To search for your TV code: Switch on television (not on standby) and aim
your ONE FOR ALL at your TV.
1. Press and hold MAGIC for 3 seconds until the blue LED (any LED) stays on.
2. Select the corresponding device e.g. TV
3. Press 9 9 1. The blue LED will blink twice (showed by going out twice).
4. Next, press POWER.
5. Press CH+ (over and over) again until your device switches OFF.
6. As soon as your television turns off, press the magic key to store the code.
Congratulations! You should now be able to switch your device back ON and
control your device successfully.
In this example we will set Volume Control (VOL+, VOL- and Mute) to "TV
volume":
2. Press 9 9 3. The blue LED will blink twice.
3. Select the corresponding device e.g. TV.
4. Press and hold the magic key for 3 sec. The blue LED will blink twice and then
Switch off.
Now you have set the Volume Control to "TV volume". The VOL+, VOL- and
Mute keys will always control "TV volume" independent which device mode
key (TV, SAT, DVD or AMP) is selected.
WWW.ONEFORALL.COM 9
OFF
SSAAT/CBL T/CBL
This feature gives you the possibility to
set the Volume (VOL+, VOL- and Mute)
to always control a certain device (e.g.
TV) independent of which device mode
e.g.: Control your TV Volume in SAT
mode.
How to deactivate Volume Control
1) Press and hold MAGIC for 3 seconds until the blue LED stays on.
2) Press 9 9 3.
3) Press Vol +. The blue LED will blink 4 times.
All devices will send out their own VOL+, VOL- and MUTE.
How to remove a device from Volume Control
2) Press 9 9 3.
3) Select the device mode you wish to deactivate from Volume Control.
4) Press Vol -. The blue LED will blink 4 times.
The removed device will send out its own VOL+, VOL- and MUTE.
Search Method
Volume Control
You may have to press
these keys many times
(up to 150 times) so
please be patient.
Jan 13, 2013 | Televison & Video
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Tv does not stay on red light blinks 9 times
Power supply board it dead,replaced this board will get ur power back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 09, 2010 | Sony QUALIA 005 46 in. LCD Television
The tv wont turn on. the red light blinks 9 times.
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
TV blinks 9 times and wont turn on please help
Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). hope it works
shaun
Aug 24, 2009 | Sony KP-46WT520 46" Rear Projection...
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDS-60A3000 60" HDTV Logo
50 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
