Question about LG " 47"" Class / LED / 1080p / 120Hz / 3D / HDTV 47LM5800"
LG 3-D TV won't power on? - LG " 47"" Class / LED / 1080p / 120Hz / 3D / HDTV 47LM5800"
LG 36in. TV. Model LST-4100A won 't come on at
There may be a power supply problem
Jun 28, 2013 | Televison & Video
Where do I find the part number on the power board for my LG 47LH40
You have to contact the authorized service centre for LG, to get an original replacement.
Jun 28, 2013 | LG Televison & Video
Hi my LG 47 LH4000 turned off and won't turn back
More than likely your power board is defective
Mar 20, 2013 | Televison & Video
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My 50in won't turn on
might have to change the bulb in the tv, should be in the back right corner should tell u something like a warning lable so u can find it,u will need a screw driver.
May 28, 2012 | LG 50PK250 50 HDTVReady Plasma TV
Connecting - flashes 3 times - picture & sound come on - flashes 2 times and turns off - won't stay on
COULD BE A SHORT IN THE POWER SUPPLY IF YOU ARE NOT A TECH THEN HAVE A TECH REPAIR YOUR TV.GOOD LUCK.
Oct 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi, i just purchased two LG LCD TV's the 26LD350 and the 32LD350 I'm worried that it does not have an off switch and only goes on to standby mode. you here alot about tv"s catching on fire because of this....
I have never heard of any LG TVs having a fire issue.
LG added this switch to help save electricity. "Going Green".
You see, this On/Off switch was added to kill the power to the TV when not in use. This switch stops the TV from consuming power by not giving it power to be in a “Stand-By” mode.
If your TV does not have this switch, you could simply unplug your TV to give you the added satisfaction it won’t catch fire.
I hope this information has helped.
Good Luck.
May 23, 2010 | LG Televison & Video
LG " 47"" Class / LED / 1080p / 120Hz / 3D / HDTV 47LM5800" Logo
21 people viewed this question
