Question about Lavelle Industries Korky& Universal Toilet Repair Kit
How do i ajust water level in a pool with a korky pool leveler
Ph level is at 'ideal' chlorine level is at 3.0 but the pool water is still cloudy. Please help?
The cloudiness could be suspended particles or algae. Use an algae k i l l er as recommended, then a flocculant (water clarifier) as recommended, then vacuum the pool bottom and run the filter overnight.
After that check the ph, alkali level, chlorine level, and adjust as needed. That should do it.
Feb 05, 2017 | Pool & Spa
Tip
Pool loosing water?
Maybe you cannot decide if the loss of water in your pool is a leak or evaporation. If you place a bucket of the pool water on a step in the pool with the water level the same inside and ouside the bucket exactly the same and run the pool pump for a day, then you will be able to tell if youi have a leak. A leak would result in a lower level in the pool after running the pump for the day. If the levels stay the same, then it is evaoporation.
on May 10, 2010 | Plumbing
Pool overfilled, I thought because of rain. This wknd I backwash drained it to the proper level. 2 days later it was overfilled again...no rain. I don't know, but think I have an auto fill.
look for a smaller cover and open it up until you find something that looks like this one or even one that could look like a toilet fill... I've seen it. Thats the auto fill and they're relatively cheap, but to save you some money look for a little outlet (1-2" hole) in the pool right near the auto fill and plug it up with a rag. if water starts coming from the top of the fill area then it could be the filler or the fitting it connects to. Once you've determined if its the auto fill then shut the water off, most times it can be shut off with the landscaping but not always, you might need to shut off the water supply for a bit. then it just counter-clock screw out put in the new one and play with the levels you want it at. DONE!
http://www.amazon.com/Water-Leveler-Valve-Restrictor-Fountains/dp/B005SVW4UU
http://www.amazon.com/Korky-528-Quiet-Toilet-Valve/dp/B00002N6MY/ref=sr_1_2?ie=UTF8&qid=1448043014&sr=8-2&keywords=leveler+fill+valve
Nov 12, 2015 | Hayward Pool & Spa
Can i change spider gasket while pool is full
In most cases, Yes!
All depends on water levels in relation to Grade of equipment to water surface level!
If filter valve is lower than level of pool surface water level, hopefully you have isolation / shut off valves before and after equipment? If you don't then answer to your question is no.
If you do have valves and when those valves are closed, then answer to your question is yes.
Answer is also yes, if pool water level is lower than filter valve.
May 13, 2015 | Pool & Spa
Anti siphon toilet water float wont ajust
mike I guess your toilet must be ok by now since your sept posting.GL
Sep 06, 2013 | Korky Universal 3in Flapper 3060BP
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
Can you ajust water level to be more in washer
No.
As with all modern machines your senses the size of the load and adjusts water levels accordingly. Unlike older machines, this means that less water is used and less energy is used to heat excess water. It also means that you get a better wash as the cleaning quality is lower if the load is sloshing about in too much water.
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lavelle Industries Korky& Universal Toilet Repair Kit  Logo
76 people viewed this question
Top Lavelle Industries Home Experts
john h
Tom Chichester
Are you a Lavelle Industries Home Expert? Answer questions, earn points and help others
