Question about Exercise & Fitness
Nordictrack audiorider u300 reed - Exercise & Fitness
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: nordictrack audiorider r400 checksum fail
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Finally tight the flexible cord form keypanel vs display board and then tight the display board vs lower board.
See if you can meassure +5VDC from lower board to display board.
see the block diagram for your final diagnostic.
12_19_2011_5_43_08_pm.gifSincerely. Merry Christmas.
Ernesto cuadra
managua,nicaragua. c.a.
Posted on Dec 19, 2011
ercupa190
  • 12223 Answers
SOURCE: remove drive belt nordic track audiorider r400
see the video and follow the steps with common sense. God bless you
Posted on Nov 13, 2012
ercupa190
  • 12223 Answers
SOURCE: how do you center the pulley onto the crank on a nordictrack u300 exercise bibe
please see the video and proceed according.God bless you
Posted on Apr 05, 2013
Will not turn on. flashing blue light
If the console only reads zeros or the controls do not function properly, try adjusting the reed switch. You will need a Phillips screwdriver to remove the motor hood and adjust the reed switch. Unplug the power cord, remove the motor hood and locate the reed switch, which is on the left side of the belt pulley. Rotate the pulley until a small magnet comes into view next to the reed switch. Loosen, but do not remove, the screw on the switch and move the switch with your hand until the gap between the switch and the magnet is 1/8 inch. Tighten the screw and replace the motor hood. The Controls Are Not Working on NordicTrack Treadmill LIVESTRONG COM
Feb 09, 2015 | Nordic Track Nordictrack C2500 Treadmill...
Run the software calibration for easy diagnose,troubleshooting, and fix it.
Happy New Year.God bless you
Dec 31, 2012 | Exercise & Fitness
Remove drive belt nordic track audiorider r400
Nov 13, 2012 | Exercise & Fitness
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
Nordictrack audiorider r400 checksum fail
Ernesto cuadra
Dec 19, 2011 | Nordic Track Exercise & Fitness
NordicTrack speeding up for no reason
This make all this adjustments:
Make sure the sensor speed is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
Good luck, sincerely.
E.CUADRA
Nov 28, 2011 | Nordic Track NordicTrack A2750 PRO...
I have a nordictrack audiostrider 800 that i just replaced the console. now the resistance won't work. thoughts?
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
  1. Replace the Batteries
    • 1 Replace the batteries first, if your machine has batteries. A manual machine such as the NordicTrack MTN 740 will not need batteries, and instead the console is powered by your moving the steps. Check your manual if you are unsure of which batteries to buy. Different machines will require different batteries. The NordicTrack Mini Stepper uses watch batteries, but larger machines will likely need AA or D batteries.
    • 2 Take off the cover to the battery compartment. Remove and discard the old batteries. Replace all of the batteries, not just one if you happen to have one good one. Align them correctly with the "+" and "-" signs as shown on the compartment.
    • 3 Replace the battery cover and attempt to turn on the console.
    Reset the Circuit Breaker
    • 1 Check the circuit breaker. A machine such as the NordicTrack CXT 990 will have a circuit breaker located on the front of the machine. The console will not work if the circuit breaker is tripped.
    • 2 Push the circuit breaker in if it protrudes until it sticks.
    • 3 Try to turn on the console. Check the circuit breaker for your house if this does not fix the console problem.
    Adjust the Reed Switch
    • 1 Inspect the reed switch as the information on the display will not be true if the reed switch is too far from the flywheel on NordicTrack machines such as the MTN 740.
    • 2 Unscrew the two M10 by 82mm button bolts on the right pedal bracket. Unscrew the two M10 nylon locknuts. Pull off the pedal bracket and set aside.
    • 3 Remove the two M4 by 38mm screws. Remove the three M4 by 25mm screws. Slide the right side shield off to expose the flywheel, magnet reed switch.
    • 4 Unscrew the screw that holds the reed switch in place but do not remove it. Slide the reed switch toward the flywheel but leave enough space that the magnet can move freely. Replace the shield and bracket
Oct 19, 2011 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
