Question about MA Audio M1889I Car Audio Amplifier
MA Audio M1889I power supply
Ampere
Is there a free medical dictionary to use online thats compatible with nokia 5233
Problems or trouble typically found on mobile phones can be categorized into
Three damage categories, namely:
1. Software Problem category
2. Hardware Problem category
3. Problem Category his SW and HW
Phone problems and solutions
1. Total dead cell phone
Mobile phones exist three kinds of die total, die total because of
· Die alone,
· Total death due to falls, and
· Death total for the taxable water.
a. Total death because death itself.
Handling:
The first can be done early steps following
- Remove the battery and plug in again, or try using another battery and try turn it
- Check the battery connector and try the press to see the level of flexible or not,
replace damaged when new.
- Connect the charging of the phone, when the indicator on the phone in and still will not turn on, then obviously you can not live on mobile phones because of interference from IC PA (Power Amplifier). After IC PA revoked your mobile phone can turn it on again. And so no signal will be installed a new PA IC.
- When the tide does not exist and charging indicator on the phone still does not want to live on should be conducted further tests using power supply. But there may also have an ugly tin on the PCB, remove the IC PA solution, then clean the tin on the PCB where IC PA stick, replace the old IC PA, HP switch, it must be a flame.
Examination with power supply:
Necessary power supply on a scale of 1 ampere ampere (A) or 1000 mA.
With the aim that the examination can be more easily and clearly.
The steps are as follows:
- Connect the cable from the power supply to the mobile phone battery connector of at least three wires, with a negative sequence, BSI and positive. (Black, green and red)
- Navigate volt power supply at 3.6 V (or in accordance with tolerance Hp-0.5 V)
- Mobile phones in the state of OFF, and press the button on
- If the current (amperage) in a digital ampere dipower supply pointer when the button is pressed on, it just means there's still a problem on its hardware (HW), it is necessary to check the components on / off until the battery.
- When the ampere when the button is pressed on, up about? 50 mA, then the problem that occurs is a matter of software (SW), then you need to do is re-programmed HP (flash) or program is upgraded to higher versions.
b. Total death from falls.
Handling:
- HP may not be tested by using the power supply, but HP should be dismantled first, heated, and repositioned back to the location / position of the components has changed as a result of HP fell.
- After that, the new HP using the power supply should be tested to determine damage to the Hardware (HW) / Software (SW).
- Most likely a damaged components as a result of the fall is the HP PA IC / IC Power.
c. Total death due to hit the water.
Handling:
- For taxable HP water is also the first time should not be tested by using the power supply, because the risk of short circuit occurs between the components in water, but must first HP divakum, heated, or by first diblower given IPA cleaning liquid, can also use the grain silica to absorb the water that existed at HP.
- After HP confirmed it was dry, then we should use the power supply to determine the damage occurred on the Hardware (HW) or Software (SW).
- At HP's exposed to water, usually there is damage to HPnya accessories.
2. Total die because of IC phone UI.
In HP's case like this then requires test equipment that is power supply.
- Connect the power supply on the phone, give the voltage (volts) equal to 3.6 V (or in accordance with tolerance Hp-0.5 V)
- At the time the phone is in off state, refer to the power supply needles amperes will increase by 100mA.
- The phone will start, LED lights, VIBRA vibrate.
Handling:
- Remove the IC UI, then turn on the phone.
- Then there is the display on the LCD mobile phone "Insert SIM Card".
- Put new IC UI.
- Turn on the phone, the phone will work fine.
3. Total dead cell phone because the CPU IC.
To determine whether the cell phone because the IC die total CPU is as follows:
- Give the voltage (volts) on the phone by using the power supply of 3.6 V (or in accordance with tolerance Hp-0.5 V).
- At the time the phone is not turned on, the needle ampere silent, but if the phone is switched on then the needle will rise 100mA amperes.
Handling:
- If the IC CPU is still in good condition, then we only need to heat the IC CPU by using a blower, but if the CPU IC is damaged, then we need to replace with a new CPU IC. Before we replace our CPU IC must first have the anti-hot glue and liquid glue crusher anti-heat, because the CPU IC is protected by anti-heat glue, after we destroy the anti-hot glue, then we can heat (blower) CPU IC for a new replacement. Similarly, after we replace it with a new CPU IC then we need to give more anti hot glue to protect the new CPU IC we replace it.
4. Total dead cell phone when we call.
For testing we use the power supply by way of:
- Connect the phone with power supply, give the voltage (volts) equal to 3.6 V (or in accordance with tolerance Hp-0.5 V) on the phone.
- Needles amperes will not move when the phone is still in a state of death.
- We turn on the phone and then used to make calls, then the needle will show the number of amperes above 400mA.
Handling:
- Replace with a new IC PA, after re-testing was done as above, if the needle test results show the figures below 400mA amperes, the phone is in good condition.
Aug 26, 2011 | Nokia 5310 Cellular Phone
My nokia 2700 is not starting up , it got disconnected while updating , now its not switching on.. what shout i do plz help
problems or trouble typically found on mobile phones can be categorized into
· Die alone,
Handling:
Handling:
Handling:
Handling:
- Put new IC UI.
Handling:
Handling:
Aug 26, 2011 | Nokia Classic 2700 Cell Phone
My monitor doesn't have an adapter. It says 12 vDC but I don't know the amperes or mA it requires, What do I do?
moz-screenshot-7.pngHi
The supply would be 12v DC 1000mA you can even go little more in amperes like 1500mA also not a problem.
DO RATE MY SOLUTION
Jun 30, 2011 | Daewoo F227B Monitor
Hi power supply whent pop. PC worked on battery for 20 mins. got new power supply but will not charge. Is there any voltage protection inside and how do I get inside My Eeee900
It is very important to check the power output produced by the ac adapter. Make sure that the output voltage and ampere of the new power supply is the same with the original power supply provided with the laptop. The new power supply you purchased may be producing lower or higher ampere than the required power to turn on the unit and charge the battery.
I suggest to purchase ASUS Eee recommended power supply or ac adapter for your laptop before it gets damage by incorrect power voltage or ampere used.
May 06, 2011 | ASUS Eee 4G Notebook
Ampers for Sony CDX-S2210S CD
If the in-line fuse from the car installation is still attached, check the fuse rating; it will state a figure that is in excess of the demand of the stereo. In other words, if the fuse has 10A on it, it was chosen to fail at currents higher than that. If this unit is only a CD player (no amplifier built-in), it will not likely draw in excess of 2 amperes and probably not over 1 ampere.
If you have no documentation, you can download what you need here:
Sony manuals for your unit
Nov 15, 2009 | Sony CDX-S2210 CD Player
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Amp is randomally shutting off
If the amp shuts down with no pattern, you need to measure the DC voltage on the power terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Since there is no pattern, you will have to watch the meter for a while so you can see the meter drop when the amp shuts off. If the meter never drops on either the remote or B+ terminals (when the amp shuts off), the amp may have an internal fault.
Apr 25, 2008 | MA Audio M1889I Car Audio Amplifier
Confused about system
If what you're telling me is correct you're trying to drive a stereo sub -woofer with a mono amplifier. If so, that could be a bad situation for the amp, if the voice coils are not wired together correctly. Before we go too far, I have some questions I need answered.
1. Is the MA unit an M1889i?
2. Do you have the 4 terminals of sub-woofer tied together. For example the 2 positive terminals are tied together & the 2 negative terminals are tied together?
3.How do you supply 12VDC to the amp?
While I'm waiting to hear back from you, I'll try to draw a schematic (wiring diagram) of the way it should be wired for your particular setup that I'll send to you.
Mar 06, 2008 | MA Audio M1889I Car Audio Amplifier
Missing power supply
locate the bottom of ur AP and read the following u should find these values:
Voltage: described by volts EX: 5 v or 12 v
Amperage: described by amperes EX: 500 ma , 1 A,....
Polarity: whre is minus and plus
write these values and u can buy any power supply or power adapter based on these values if not sccseeful write me ill help u more
wafik_eid@hotmail.com
Nov 21, 2007 | Arris WA840G 802.11g/b (49832000100)...
Amp randomly comes on and off
You may have an intermittent power problem. You will need a schematic and a multimeter to the the power supply voltages in the amplifier.
Sep 07, 2007 | MA Audio M1889I Car Audio Amplifier
MA Audio M1889I Car Audio Amplifier Logo
27 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
Robert Rankin
Ronald Prier
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
