Question about Kenmore Sewing Machines
Needle tip breaks after sewing a few seconds. Tried re-threading. I don't have the manual for the machine (kenmore model # 158.16011). Is this a tension issue or a bobbin issue??? Or something else?
It was a tension issue and the bobbin case was coming apart. I re-assembled the case and adjusted the tension and TA-DA - it works!
Posted on Jun 25, 2009
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Kenmore sewing machine jams and breaks the needle
always make sure the needle is inserted correctly and all the way
up into the needle holder
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin case is inserted correctly in to the machine
if it's a front or side loading bobbin case
make sure the top thread has not come off the top thread take up
lever
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 01, 2012 | Kenmore Sewing Machines
Can not get machine to work, no manual, knots up and breaks thread right away 20 15516 machine can you help?
First check in the bobbin area for lint, bits of thread wrapped round parts.
Then make sure your needle is oriented and inserted fully.
Also when starting a seam be sure to grasp both of the threads and hold them as you start to sew.
If you still have problems, make sure your thread and needle are suitable for your fabric.
Since you don't really say where it knots and breaks ... it could also be a damaged needle plate.
Oct 05, 2012 | Kenmore 15516 Mechanical Sewing Machine
I have an old Featherweight Singer which threads backwards. When I replaced the needle, and threaded the machine, every time it unthreaded after a few seconds sewing. We tried threading the other way as...
Look at your model number on your machine, then go to singerco.com and you can download a copy of your manual, usually, for free. You could also call the customer service number at 1-800-4singer
Sep 11, 2010 | Singer Sewing Machines
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
Needle tip breaks when machine makes a few resolutions
You may be using the wrong needle for the thread that is currently in the machine. Check the manual that came with your machine to see what needle size is suggested for your project's thread and fabric.
Oct 20, 2009 | Singer Quantum XL-6000 Computerized Sewing...
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
95 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
