Question about Sub-Zero 561 / F
What is desired temp for refrigerator - Sub-Zero 561 / F
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 489 Answers
35-41
Posted on Jun 13, 2015
Temp.Control Panel indicator is Red, what can i do?
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place. 192 168 1 1 192 168 1 1 admin password log in
http://www.routermobile.com/ 192 168 192 168 1 1 Login Admin Password http://www.19216811254.com/
Aug 18, 2015 | Fisher and Paykel Active Smart E522B...
Da99 samsung fridge freezer
As for freezer, lower the letter and allow 24 hours for temp to adjust. Lower again and wait, until desired temp achieved.
Do the same thing for refrigerator. If freezing not working most efficiently, this can and usually does affect the refrigerator.
Go to http://www.buzzle.com/articles/refrigerator-temperature-settings.html for more info.
Mar 02, 2014 | Refrigerators
I am a florist with a 26 feet src refrigeration box (unit), I cannot control the temp at the desired rate, it keeps fluctuating to a higher (hotter) temp. Need your advise
your going to adjust the thermostat setting if your thermostat is digital type you press it yuor desired temp. ex from 10 to 1 to adjust it to cool if your thermostat is analog to adjust it to cool rotate the knob clockwise to adjust the setting to cool but observe it to get you desired temp.
Mar 02, 2011 | SRC Refrigeration LD126-4 10'6' LongDoor...
Hi samsung fridge runs fine gets to desired temp then wont kick in again until it warms up.
the fridge will run until it reaches the temp. there should be a differential of 2 degrees so when the temp rises by 2 degrees the fridge should restart so you will need to make sure the differential is set to 2 degrees celcius on controller
May 21, 2010 | Refrigerators
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
The refrigerator does not seem to be working though the bottom freezer is working. Is there anything I can do myself to check it?
change the temp setting two steps lower and wait for about 4 hours. that's the amount of time it takes for it to reach desired temp...
Jul 09, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
GE GSS25LGMA WW FREEZES FOOD
These refrigerator use the cold air from the freezer the cool the refrigerator. At the rear of the upper refrigerator compartment, there is a shroud. Remove the shroud and you should see a "flapper" that shuts off the cold air when desired. You will most likely see the flap is broken. Once the flap is broken, you lose control of your refrigerator temp. This is a common problem with this refrigerator.
Hope this helps.
Jan 11, 2009 | Refrigerators
Correct Temp
frezeer 0% to 5 refrigerator section 36 to 38
Oct 31, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
