Hisense tv remote control
My toddler has been playing with the Hisense remote. Now I can't change the source. We are stuck on DTV and can't change to AV to watch DVD's? I have changed the batteries, so that is not the problem. Is there a button in the controls that I need to press to get the source back. Seems no signals are showing at all. Volume bar no longer shows, however volume does go up and down. Source no longer appears?
  • 194 Answers
Get a new remote
Posted on Aug 01, 2017
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 223 Answers
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 362 Answers
SOURCE: Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Posted on Jan 11, 2009
no canbias
Posted on Oct 12, 2009
Source button does not work The hisense Tv cannot respond to change to hdmi and is stuck on monotv
new batteries. But that won't solve the problem if the universal remote apply other code. when the original remote is applied, you touch the tv icon to be sure you are using the correct parameters. When it still won't solve the problem you go to the ir circuit on the set. the reason may be because of the accumulation of the dust and dirt on the buttons.
Apr 30, 2016 | Hisense Televison & Video
Others moved TV setting to AV-1 to watch DVD.I cannot get it return to TV mode.
input source !
On the remote control of the tv should be an input source button
press this and select DTV
Sep 19, 2015 | Televison & Video
Dvd player dvd does not show on tv screen
swop the TV back over to what ever you use for watching TV i.e.........HDMI 1 / HDMI 2 / AV 1 / DTV / etc.
Use the AV or SOURCE button on the TV's Remote, not your receivers remote or SKY remote.
Feb 12, 2014 | Pioneer BDP-LX52 Installed
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Jan 01, 2011 | Televison & Video
My tv has a "game" button and that is the only way my dvd will play on it. Hope this helps.
Jan 16, 2009 | Hisense LCD1504 15 in. Television
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Televison & Video Logo
Top Televison & Video Experts
