Question about DeLonghi EC702
How do we get water through my EC702. It was fine - now water won't come through. We cleaned the filters
It was fine now won't put water through. wand works fine. we cleaned out the filters etc.
2 Suggested Answers
  • 2039 Answers
SOURCE: how do i clean the pump for the delonghi ec702?
you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
Posted on Dec 13, 2008
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
Why is my delonghi ec702 brewing slowly even after regular descaling? The water barely drips out even with no coffee in the filter.
I had same problem, now gone. Check your water Intake filter in the water reservoir. If it looks discolored, it may be clogged. I used a brush and plain water to clean it off, and now machine works like brand new!
Jul 28, 2014 | DeLonghi EC702
My ec702 stopped pumping water through. the wand still works. we descaled and cleaned out all filters. nothing. how do we fix it?
I suggest you try cleaning/descaling again. Possibly the scale that was loosened did clog the coffee maker up.
May 12, 2014 | DeLonghi Pump Espresso Machine Stainless...
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
Motor starts and pump is not working. No water is flowing at all..what do i need to do?
Water is supposed to flow slightly through the pump without it running so disassemble the wand and cut on water supply, see if water comes out of the wand on-off handle. The motor does not have to be running. Got water flowing? YES - clean out the wand filter or nozzle hole. A partially clogged filter will prevent hi pressure activation.
NO? disassemble pump and clean out chamber paths.
Also - A pressure pump is not suppose to be running and not used for over ten minutes. The pump can overheat from lack of water passing through and damage the pump seals. A clogged wand is the same as not using it while you try to figger out why it doesn't have high pressure. I found my clogged filter and stopped up nozzle but haven't gotten my real high pressure back yet. Sears doesn't sell the valve seal kit but someone does.
May 04, 2009 | Garden
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
How do i clean the pump for the delonghi ec702?
Dec 13, 2008 | DeLonghi EC701 Espresso Machine
DeLonghi EC702 Logo
168 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
