Question about Mercedes C-Class Exterior Pillar Posts Trim Set
What is gas gauge fuse called for benz c320. - Mercedes C-Class Exterior Pillar Posts Trim Set
  • Mercedes-Benz Master
  • 2,210 Answers
It won't be fused separately, the gauge will be covered by the dash fuse. If the gas gauge is not moving then check the wiring by tracing the sender unit at the tank. It may be accessed through a small panel in the trunk floor. Pull off the sender wire, ground it on a clean metal surface and with the ignition ON, see if the gauge moves. If it does, then suspect the sender.
Posted on Jul 30, 2014
Where is the fuses for fog lights?
if fuse is out either light would not work. The wire is bad some where or the bulb is out
Jul 12, 2015 | 2002 C320
2002 c320 radio and cagarite lighter do not work.
Had the same issue on 2002 c320 . look at the fuse chart ,find out the fuse # that operate the radio and the cigarette lighter , you have three fuse boxes, engine compartment, driver left knee and trunk on left .find the fuse b compairing the char to the box , replace the fuse . DONE
Jul 01, 2014 | 2001 Mercedes-Benz C-Class
I have a 2004 Benz c320. When turn the car on none of the gages move, my I van't control my windows or anything else electric, I thought it was the battery at first, bit it runs fine. But when I'm...
Check all your fuses . Remember you have more than one fuse box. If the fuses are good ,then it looks like a problem in the SAM unit,, it works all equipment /Check for water ingress in the same area as the SAM unit it will cause problems if its wet..
Dec 16, 2017 | Mercedes-Benz C230 Cars & Trucks
Is there a fuse for the fuel gauge on a 2003 mercesdes benz c320
You may go to your owners manual and look for a page that discuss about fuel fuse.
Jeep Tops and Jeep Soft Tops
Smit
Mar 17, 2013 | Mercedes-Benz Cars & Trucks
Do you know which fuse controls the lighter in a mercedes benz 2001 C320
FUSE 23 15 AMP FUSE LOCATED FASCIA FUSE BOX
Open drivers door unclip panel end of dash
Mar 21, 2011 | Mercedes-Benz C-Class Cars & Trucks
The speedometer odometer gas gauge and rpm gauge arent working it doesnt appear to be a blown fuse, could it be somehting else with the fuses
try disconnecting your battery and reconnect,gonna screw up your preset radio stations but it worked on my daughters car
Feb 03, 2010 | 1993 Mercedes-Benz Mercedes Benz 400 Class
Show me how to route a serpentine belt for a 2001 mercedes c320.
2001 MERCEDES-BENZ C320 - V6 3.2L 3199cc GAS FI N
Belt Routing Diagram Multiple Accessory
DAYCO Catalog
I hope help you with this (remember rated this help). Good luck.
Sep 23, 2009 | 2001 Mercedes-Benz C-Class
Need a fuse box diagram for a c320 dagram is missing from fuse box. Need to find the fuse for the cigarrette lighter
hello,fuse number 47 at your engine room,open your hood,right side,standing in front your car, or you can order to your dealer,fuse designation,ty
Apr 21, 2009 | 2001 Mercedes-Benz C-Class
2002 MB C320 gas cap problem
I had the exact same problem, went to the Mercedes dealer and they fixed it for free with a pair of pliers. They just pulled up the metal clips and turned them back into place.
Jan 04, 2009 | 1997 Mercedes-Benz C-Class
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
114 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
